is it possible to get rotors slotted?
Postby sik_gt_starly » Fri Aug 07, 2009 9:47 am
Just bought some new brembo front rotors, was under the impression from the sales person they were slotted however upon taking them out of the box they wernt.
They were pretty cheap so im wondering if anyone knows if its possible and or how much it costs to get rotors slotted, also where i could go to get it done.
Have asked around whakatane and no one knows, some saying theres no need to slot the rotors as these will work a charm as they wont warp or anything being good quality
others saying if youre gunna do some track racing you should get them slotted
others saying take rotors back and buy a set that are slotted, i was thinking it may be cheaper to pay to get these slotted as may be cheaper than returning and buying already slotted ones
others saying yes they can be slotted by an engineering place but none know who does it
any help appreciated
sik_gt_starly
Postby Mr.Phreak » Fri Aug 07, 2009 10:20 am
It's not something I'd do
Mr.Phreak
Postby tsoob » Fri Aug 07, 2009 10:52 am
i put a set of replacement brembo (non slotted) onto my mates rx7 and they were dope with the right pads.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby FLAWLES » Fri Aug 07, 2009 11:21 am
it can be done
weather or not you want to do it to your brembos is another question
i done it to my factory rotors on my jzx100 a year and a bit ago, and there fine, as long as they havent been through some hard out heat cycles and are showing signs of fitague ( sp ? ) they should be fine, and im talking about your factory rotors not the brembos
mine have been through four track days, a few " sprited " touge runs and daily driving, and are fine
but race brakes should be able to slot your brembos for you if needed
FLAWLES
Postby Kittah » Fri Aug 07, 2009 11:42 am
I'd imagine this would be similar to getting non-crossdrilled rotors crossdrilled, in that it would affect the structural integrity of the rotors. I'm not engineer though, so don't take my word for it :D
Kittah
Postby Adamal » Fri Aug 07, 2009 12:14 pm
Yea... It kinda falls into the same catagory as 'lightening flywheels' for me... I'd much prefer to get things that have been manufactured that way.
Postby Akane » Fri Aug 07, 2009 12:59 pm
Did you get them at 0800 brakes?
Postby sik_gt_starly » Fri Aug 07, 2009 1:12 pm
nope got them from bnt.
phoned 0800brakes but they do not slot rotors, only sell already slotted ones, i have got a quote but a bit out of my price range atm.
0800brakes did say it is possible to slot rotors, just to make sure the engineer knows what they are doing, do not want them to get ruined and shatter etc
Am thinking i will stick with the brembo replacement rotors and match them to some decent pads i can use for a bit of track use in the starlet as i have my cheapy trueno for a daily
sik_gt_starly
Postby GTCRSHR » Fri Aug 07, 2009 1:19 pm
sik_gt_starly wrote:only sell already slotted ones,
were they much more than the ones you got from bnt?
Nothing to see here ...
GTCRSHR
Postby sik_gt_starly » Fri Aug 07, 2009 1:22 pm
alot more, DBA slotted ones from 0800brakes 240+gst each
non slotted brembos 125 for 2
sik_gt_starly
Postby strx7 » Fri Aug 07, 2009 6:10 pm
I'm assuming they are for an EP82 that you are talking about, what is the car going to be used for?
Postby sik_gt_starly » Fri Aug 07, 2009 8:47 pm
roger for an ep82, mainly used for weekend cruzing & bit of track use, nothing too serious
have my trueno as a daily
sik_gt_starly
Postby Boost_4_Life » Fri Aug 07, 2009 9:08 pm
just put decent pads and use the rotors you bought. you do not need slotted... we run tarmac track cars & rally cars and dont run slotted on any of them.
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby matt dunn » Fri Aug 07, 2009 9:09 pm
can you get rotors slotted, yes.
cost, when I bought new willwood disc's, it was $60 extra per disc,
and they got them done somewhere, as they didn't stock the slotted ones.
getting them cross drilled after manufacturing, i'd doubt it.
Postby mjrstar » Fri Aug 07, 2009 9:41 pm
grinder and a protractor it's all you need.... plus a bit of patience. seen it done on some pretty high spec cars and have hand slotted my own also..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby jakesae101 » Fri Aug 07, 2009 10:02 pm
mjrstar wrote:grinder and a protractor it's all you need.... plus a bit of patience. seen it done on some pretty high spec cars and have hand slotted my own also..
say what
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby strx7 » Fri Aug 07, 2009 10:21 pm
Boost_4_Life wrote:just put decent pads and use the rotors you bought. you do not need slotted... we run tarmac track cars & rally cars and dont run slotted on any of them.
Amen, Unless you are building a vehicle which will see longish track use, say 5 lap races or longer I wouldn't bother with slotted discs, and then if you're doing a car for that purpose you'd ideally want floating discs anyway.
Postby steve murch » Mon Aug 10, 2009 2:53 pm
sik_gt_starly wrote:nope got them from bnt.
thats fummy cause i use to slot tons for them,and it doesnt hurt the disc
steve murch
Postby Adamal » Mon Aug 10, 2009 3:30 pm
I guess that settles it then. Take them to Steve!
Btw Steve, was just down at Alphakarts, and Matt there says yours is pretty damn fast!
Postby steve murch » Mon Aug 10, 2009 6:54 pm
Adamal wrote:I guess that settles it then. Take them to Steve!
its not bad but has issues
trying to lose weight out of it as it wont get off the corner now with sticky tyres,now has heaps of carbon fibre on it and its about to lose the clutch
things you have to do to go fast,lol
steve murch
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
