Here are a few pics of the current item. Any one know of somewhere i can get one of these but longer without going to an engineer?
Matt
fivebob wrote:Then I suggest you go to an engineer as I doub't you'll find anything that will meet your needs off the shelf. They could make one up quite easily and it shouldn't cost that much.
fivebob wrote:Don't use brass pipe if you want it to hold together, brass will fracture from the vibration. It needs to be steel.
thegreatestben wrote:seem to remember a 1ggte having alonger one due to having an oil cooler between the block and filter.
Not sure if same thread though
Users browsing this forum: Google [Bot] and 2 guests
