Looking at taking the charcoal canister out of my ma61.
I want to remove the hard line from the back of the car (tank to canister) as well.
Will this be a problem?
RomanV wrote:Also, any cars certed some time next year or onwards will be required to have a cat converter fitted....
deaf_rattle wrote:RomanV wrote:Also, any cars certed some time next year or onwards will be required to have a cat converter fitted....
any info on that?
Positive crankcase ventilation
means a system which re-directs crankcase blow-by to the intake manifold and back to the engine, where it is re-burned in the cylinders as part of the fuel/air mixture. This cuts emission pollution and increases fuel economy because partially or un-burned fuel in the blow-by is consumed the second time around, in addition to keeping the blow-by and water vapour from fouling the oil in the crankcase, thus reducing the formation of engine sludge. Positive crankcase ventilation is also an essential aid against internal engine pressurisation and subsequent oil leaks - which is particularly handy if your engine was manufactured in England.
