charcoal canister required?
Postby deaf_rattle » Thu Aug 13, 2009 9:17 pm
Looking at taking the charcoal canister out of my ma61.
I want to remove the hard line from the back of the car (tank to canister) as well.
Will this be a problem?
Postby t0ms » Thu Aug 13, 2009 9:27 pm
not really. boats dont have them at all. i think they're just there to allow an area for fuel vapours to collect and turn back to liquid before re entering the tank
that being said if you do remove it you will need to have a breather from your tank as they are usually sealed so with no area for the vapours to collect the tank could pressurise
t0ms
Postby Mr Revhead » Thu Aug 13, 2009 10:22 pm
yeah its an emissions thing
but don't tel the govt or they will make u need them!
Postby XS1V » Fri Aug 14, 2009 12:29 pm
You will need to keep the breather pipe, just put a small simota filter on it or plumb into your catch tank :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby bluemaumau » Fri Aug 14, 2009 1:22 pm
interesting thing, my mate went into get a cert on his rb20det c33 yesterday, and got told he needed to have positive crank ventilation, which in short means the breathers (which currently go to a catch can) need to be plumbed into the intake, he suggested before the turbo.
said it was a new emissions thing for certs
whatever,
surely you could just loop them back up to each other (not good i know) but he cant not certify that surely?
/semi related :lol:
Postby RomanV » Fri Aug 14, 2009 1:30 pm
Also, any cars certed some time next year or onwards will be required to have a cat converter fitted....
Postby deaf_rattle » Fri Aug 14, 2009 3:09 pm
RomanV wrote:Also, any cars certed some time next year or onwards will be required to have a cat converter fitted....
any info on that?
Postby RomanV » Fri Aug 14, 2009 3:35 pm
It's on the low volume vehicle certification website, cant find it just now.
Technically I think I also recall reading somewhere that you do need a charcoal cannister for either cert, or wof, or something. technically :P
Postby XS1V » Fri Aug 14, 2009 3:45 pm
Most "WOF Inspectors" would not even know what a charcoal canister is :roll:
XS1V
Postby Distrb » Fri Aug 14, 2009 4:09 pm
any info on that?
http://lvvta.org.nz/stdExhaustGasEmissions.pdf
read Section 2.5(1)
Suggests to me you'll only need to fit cats if you're undergoing an engine conversion using a modern engine.
Distrb
Regular Poster
Postby DeeCee » Fri Aug 14, 2009 4:40 pm
I didn't realise they put jokes into the standards:
Positive crankcase ventilation
means a system which re-directs crankcase blow-by to the intake manifold and back to the engine, where it is re-burned in the cylinders as part of the fuel/air mixture. This cuts emission pollution and increases fuel economy because partially or un-burned fuel in the blow-by is consumed the second time around, in addition to keeping the blow-by and water vapour from fouling the oil in the crankcase, thus reducing the formation of engine sludge. Positive crankcase ventilation is also an essential aid against internal engine pressurisation and subsequent oil leaks - which is particularly handy if your engine was manufactured in England.
:lol:
GT Four Adovansu
DeeCee
Postby deaf_rattle » Fri Aug 14, 2009 6:52 pm
sweet, just gotta make sure my supra is all certed before may 2010.
