[pointless idea forums] Using a distributor to run coilpacks
Postby RomanV » Mon Aug 17, 2009 8:23 pm
Seems as though it would be pretty easy to make Toyota coil on plug setup work, with a distributor reconfigured to send the signal to fire them.
Coilpacks have 4 pins:
1. Main 12V supply
2. Signal to fire from ECU (I think the ECU earths out this pin when wanting to fire)
3. Confirmation of firing, signal returned to ECU
4. Main Earth
So if you wanted to run them via a distributor, you'd obviously not use the coil feeding it anymore, but have the cable that normally comes from the coil, just earthed to the chassis or engine block. And obviously what was formerly a spark plug lead would just be the wire to earth out the pin on the coilpack.
Then you'd just need to supply the other 2 pins with 12V and earth, and the 4th pin (confirmation of firing) would be redundant.
Buying a set of coilpacks is same price if not cheaper than spark plug leads these days, with common cars using them.
converting a distributor'd car to a dizzy/coilpack setup could be easy enough... maybe better reliability? Stronger spark perhaps...
Or is the only advantage of a coilpack setup the precision with which they can be fired by the computer...
Postby MR2BOY23 » Mon Aug 17, 2009 8:29 pm
My friend used coilpacks on his type r turbo engine.
Apparently the stock ignition couldn't provide enough spark higher in the rev range, so thats one advantage
MR2BOY23
Postby RomanV » Mon Aug 17, 2009 8:31 pm
Could be an easy way to upgrade ignition for 4AGEs etc, while still being able to use standard computer.
Postby jakesae101 » Mon Aug 17, 2009 8:35 pm
why not run the 4agze wasted spark setup?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Lloyd » Mon Aug 17, 2009 8:59 pm
2 wire coils would be the easiest. And the confirmation bit you are talking about on extra wires is only for the ECU, makes no difference to the coil
Why would you want to? If your ignition system isn't up to whatever you've done then I'd be guessing an aftermarket ECU would be on the cards already and it would happily do multiple coils without the need for a dizzy except as a cam/crank angle sensor. Which is essentially what a lot of late Toyota distributors are anyway. Even early ones for that matter
Postby RomanV » Mon Aug 17, 2009 9:15 pm
Lloyd wrote:Why would you want to?
Toyota wanted $300 for a set of spark plug leads...
Vs the ~$0 it would have cost me to make some coilpacks work instead.
On an older car it could potentially be cheaper and not much harder to convert to coilpacks in that manner, than it would be to buy a set of spark plug leads.
I ended up just getting some leads for $8 from Pick a Part anyway, but was just a thought I had while thinking how to not spend $300 on a $500 car. :P
Postby gasman » Mon Aug 17, 2009 10:53 pm
http://forums.club4ag.com/zerothread?id=18900&page=1
maybe you should tell this lot your idea
"What can possibly go wrong?"
gasman
Postby MAGN1T » Mon Aug 17, 2009 11:07 pm
I think it's one of the silliest ideas I've ever read about.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby NZ_AE86 » Mon Aug 17, 2009 11:17 pm
Dwell?
This is the most upsidedown idea this week.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Mon Aug 17, 2009 11:55 pm
dave thinking outl oud again, don't shoot him down... usually quite good when he gets in his stride :P
Postby fivebob » Tue Aug 18, 2009 12:03 am
Won't work unless you want to run a huge signal amplifier. The gap between rotor & dizzy cap is ok @ 40,000v but won't pass enough of a signal @12v to activate the coils.
