Wanting help designing a template for caliper adapters
Postby cat007 » Fri Jul 17, 2009 3:21 pm
I'm needing someone to design me a template and/or 3D drawing to get my caliper adapters made.
I can supply the hub, rotor and caliper with pads.
Anyone on here that way inclined?
Postby mjrstar » Fri Jul 17, 2009 4:34 pm
i made my own out of customwood and had a machininst make up steel ones as i decided the wooden ones might not last too long if they got wet.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Re: Wanting help designing a template for caliper adapters
Postby Bazda » Fri Jul 17, 2009 4:51 pm
cat007 wrote:I'm needing someone to design me a template and/or 3D drawing to get my caliper adapters made.
You can take it to Precision engineering and he will do it all for you.
How much it costs... not sure.
I usually make a mock up out of MDF. Then draw it up in CAD and get it laser cut.
If you make the mock up from MDF or what you need, I can draw it up in CAD and get it cut for you.
Postby cat007 » Fri Jul 17, 2009 4:52 pm
har har
but ok - I'll try and make some this weekend I guess lol
Thanks - I'll try and make a mock up with MDF this weekend....
Postby cat007 » Mon Aug 24, 2009 11:22 am
Ok so I've pretty much made a design from a polycarbonate type material
I'll finish it off this week and get it perfect then work out the bolt hole spaces exactly - although that's something I'd do after the bracket was cut....
I'll be in touch Bazda :)
Also - I require it to be stepped - like the pic below (that would be looking side on, (red lines are where the caliper bolts go through, green are where the hub bolts go through)). I was wondering if it would be ok to just use a single flat piece of plate steel/aluminium and then just space out the caliper somehow - or should It all be one piece?
Cheers :)
Postby mjrstar » Mon Aug 24, 2009 2:15 pm
1 piece, flex is bad.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby cat007 » Mon Aug 24, 2009 2:19 pm
mjrstar wrote:1 piece, flex is bad.
Aluminium would be ok? Even if pricier?
Postby Bazda » Mon Aug 24, 2009 2:21 pm
Depends how thick that plate is. And how long it is.
Cheapest way is to make it out of 1 flat piece, then get spacers lathed up to the required thickness.
If you make it out of 1 thick piece then there will be machining costs involved.
Postby cat007 » Mon Aug 24, 2009 2:23 pm
Bazda wrote:Depends how thick that plate is. And how long it is.
I would initially get them water cut, then take to a machinist to finish it off.
Well the thinnest piece could be anything up to +15mm....then the 'step' where the caliper would bolt up to would be another 6-7mm on top of that.
Postby Bazda » Mon Aug 24, 2009 2:26 pm
1 flat piece 15mm water cut. Then get spacers made. Would work out really cheap.
I would think the plates would cost $50 each, the spacers would be cheap as like $40 to be lathed up.
For 15mm I would learn towards steel not aluminium.
Postby cat007 » Mon Aug 24, 2009 2:29 pm
Well I was only suggesting 15mm - I could go bigger or smaller. just saying that I've got a far bit of room to play with....
If aluminium - what size should I go at the thinnest point? And what about steel?
Here's some pics of the mock up :)
http://s271.photobucket.com/albums/jj123/5uprah/brakes/
Postby sergei » Mon Aug 24, 2009 2:29 pm
Also make sure bolts are up to it (ie have same strength as OEM or better).
Postby cat007 » Mon Aug 24, 2009 2:31 pm
sergei wrote:Also make sure bolts are up to it (ie have same strength as OEM or better).
Was thinking of getting new HT ones (cant remember the strength number) from 'the bolt shop'
Postby Bazda » Mon Aug 24, 2009 2:50 pm
I'm not sure how thick you would need to go... but mine are 20mm thick at the thinnest point and 35mm at the widest. Also with a huge radius on all edges.
From your pics... doesnt tell us anything about how to make the adapter plate really lol
Postby cat007 » Mon Aug 24, 2009 2:52 pm
Bazda wrote:I'm not sure how thick you would need to go... but mine are 20mm thick at the thinnest point and 35mm at the widest. Also with a huge radius on all edges.
Nah I know - I haven't taken any decent pics yet. Just wanted some of the caliper and rotor in place :)
I'll take some decent ones tonight
Are yours aluminium Barry?
Postby Bazda » Mon Aug 24, 2009 3:41 pm
yes
Postby cat007 » Mon Aug 24, 2009 3:43 pm
Any hookups for getting some, say, 30-35mm thick aluminium?
I imagine Ulrich will find the nearest barrel to bend me over...
Postby Bazda » Mon Aug 24, 2009 3:47 pm
Just go down to Nalco and ask them for some alloy.
I can get it cheaper but need to know the exact amount you require.
If you get it water cut they supply the material.
Postby cat007 » Mon Aug 24, 2009 3:52 pm
what sort should I use?
