Wanting help designing a template for caliper adapters
Postby Bazda » Mon Aug 24, 2009 3:58 pm
cat007 wrote:what sort should I use?
6061.
http://www.nalco.co.nz/userDocuments/NA ... %20bar.pdf
Postby cat007 » Mon Aug 24, 2009 4:20 pm
6061.
Thanks for that. The biggest they have is 150mm long (I assume that's mm?) which is probably not going to be enough - the calipers are "wide mount" calipers....
I'll measure everything up tonight and let you know the size of aluminium I'd need and could you get me a price?
Cheers :)
Postby Bazda » Mon Aug 24, 2009 4:54 pm
cat007 wrote:
6061.
Cheers :)
No 150mm wide, length you can get it cut to what you want.
Postby cat007 » Mon Aug 24, 2009 4:56 pm
ah - got ya
I'm trying to picture how wide I'd need it to be - probably 60mm would do me actually...
Postby lee90 » Mon Aug 24, 2009 7:26 pm
hi man how much to get the brake done by you?
because i have got brombo brakes.
lee90
Postby Bazda » Mon Aug 24, 2009 7:40 pm
lee90 wrote:hi man how much to get the brake done by you?
If you give to me in Late October I can do thsi for you. But it wont be cheap to set up your brembos! and I hope you will be running 17" wheels.
PM me for details.
Postby jakesae101 » Mon Aug 24, 2009 7:40 pm
is that a rip off of a brembo?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby cat007 » Tue Aug 25, 2009 10:56 am
attn: Bazda
Ok so - I need it just over 60mm wide and 30mm thick would be sweet
I was thinking this:
Order code: 804657 - Die number: EF0317
Can you get me a price on 400mm of that?
Cheers :)
