cat007 wrote:what sort should I use?
6061.
http://www.nalco.co.nz/userDocuments/NA ... %20bar.pdf
Bazda wrote:cat007 wrote:what sort should I use?
6061.
cat007 wrote:Bazda wrote:cat007 wrote:what sort should I use?
6061.
Thanks for that. The biggest they have is 150mm long (I assume that's mm?) which is probably not going to be enough - the calipers are "wide mount" calipers....
I'll measure everything up tonight and let you know the size of aluminium I'd need and could you get me a price?
Bazda wrote:
No 150mm wide, length you can get it cut to what you want.
lee90 wrote:hi man how much to get the brake done by you?
because i have got brombo brakes.
