Harlet wrote:C56 lsd unit will fit into a C52. From memory they came out in some AE101's and AE111's. But like Stu said, they are rubbish. I had one but opted for the TRD unit instead.
DRFTIN wrote:Harlet wrote:C56 lsd unit will fit into a C52. From memory they came out in some AE101's and AE111's. But like Stu said, they are rubbish. I had one but opted for the TRD unit instead.
throw a shim or 3 in there and they're not too bad
i never had a problem with spinning 1 wheel in the old race car anyway
AceSniper wrote:viscous ones wont fit a normal c series think the housing is a little dif? see all the c series aftermarket lsd's can work in ep's except those that have the std viscous, unless its due to the different shafts
iOnic wrote:Google search how to shim a viscous diff
Viscous LSDs are less efficient than mechanical types, that is, they "lose" some power. They do not stand up well to abuse. In particular, any sustained load which overheats the silicone results in sudden permanent loss of the differential effect.[4] They do have the virtue of failing gracefully, reverting to semi-open differential behaviour. Typically a visco-differential that has covered 60,000 miles or more will be functioning largely as an open differential
mr30%jr wrote:you can shim any dif.. doesnt make it lock up any better i think your confusing clutch packs with viscous, its mainly changing the fluid which cures them but they are shittastic to begin with
iOnic wrote:mr30%jr wrote:you can shim any dif.. doesnt make it lock up any better i think your confusing clutch packs with viscous, its mainly changing the fluid which cures them but they are shittastic to begin with
Mine seemed to "lock up" a whole lot better when I added an extra shim in it. Felt like new again and was way more consistent. No I'm not confusing clutch pack LSD's with viscous LSD's - Unless starlet's and MR2's come with clutch pack LSD's stock...
