KE20 4AGTE 20v Silvertop
Postby blue_devil_21 » Sun Sep 06, 2009 7:34 pm
I’m partway thru this build and I’ve been told that I need bigger injectors. Some have said "gets some out of a supra" or "injectors from a Caldina would be sweet"
Does anyone know which engine to get the 'right' set of injectors from... if there is such a thing?
I’ve done a little bit of research online and haven’t found a lot, but found that the standard injectors in a 20v Silvertop are side-feed, and when I went into Toyota, the guy said the injector that I had in my hand was top-feed... WTF! I then went on Trademe and looked at pics of top-feed and side-feed and am pretty sure the dude at Toyota is wrong...
I’m starting to babble a bit, but can anyone here give me some helpful advice?
Cheers,
Anand
blue_devil_21
Postby bs » Sun Sep 06, 2009 7:52 pm
Gen I, as fitted to the ST165 are top feed and will not fit.
Gen II, (early SW20 & ST185) are 430cc Side feed injectors and will fit.
Gen III (ST205 & SW20 after Oct '93) are 540cc side feeds and will fit.
Gen IV (ST215) are top feed and will not fit.
bs
Postby Flannelman » Sun Sep 06, 2009 8:38 pm
thats abit better than i found.
anyway, how much power are you after?
rule of thumb is Hp x 6 = fuel needed.
stock 20v injectors are 295cc. total flow is 1180cc, divide by 6 = 196.6Hp (146kW) altho this doesnt take into acount the cycle rate of injectors.
Flannelman
formerly known as Affroman
Postby matt dunn » Sun Sep 06, 2009 9:29 pm
bs wrote:Gen I, as fitted to the ST165 are top feed and will not fit.
Correct,
and also non-vvti 2JZGTE fit also,
so possibly 1JZGTE also,
but the 2JZGTE's are 430 jap spec and 550 USA spec.
Matt
Postby bs » Sun Sep 06, 2009 10:00 pm
Correct,
Matt
Serch for the win, Quoted from Fivebob so must be right :lol:
bs
Postby blue_devil_21 » Tue Sep 15, 2009 12:39 pm
hey thanks guys! your time and effort is really appreciated! :D
blue_devil_21
Postby sergei » Tue Sep 15, 2009 1:13 pm
There is also 1JZ variant with 380cc side feed.
Postby AceSniper » Tue Sep 15, 2009 1:23 pm
yellow 1jzgte ones 380cc
3sgte side feed blacktop 440cc?
vvti 2jzgte pink top ones also fit 440cc?
I have some 3sgte black ones if your stuck pm me
AceSniper
Postby blue_devil_21 » Tue Sep 15, 2009 1:36 pm
thanks guys, i think im gonna look for some 540cc's from st205
blue_devil_21
Users browsing this forum: Google [Bot] and 24 guests
