Installing BOV
Installing BOV
Postby DXROLLA » Tue Sep 08, 2009 10:44 pm
Hey i have a bov lying around its just a cheapo and was wondering how to install it, the thing im confused about is that where it goes onto the factory hose it has these 4 screws that you screw in and than nuts you tighten up, but i thought that it would just fly off under pressure or leak as i cant see how it would seal? Or am i missing some part of the assembaly.
Its getting installed onto a 'cough' GTX 'cough' if that matters?
DXROLLA
Postby no_8wire » Tue Sep 08, 2009 11:28 pm
Pics may help your case.... :wink:
no_8wire
Postby DXROLLA » Wed Sep 09, 2009 10:51 am
DXROLLA
Postby tsoob » Wed Sep 09, 2009 11:09 am
you are missing a piece of the bov. it screws into the bottom of it, is it a GFB valve?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby DXROLLA » Wed Sep 09, 2009 11:11 am
No just a cheap one i got a couple of years ago, xspower or something? Is it possible to buy the part im needing or maybe get it made?
DXROLLA
Postby Paulio » Wed Sep 09, 2009 11:37 am
Its suppose to mount to a perfect fitting pipe off your intake piping, it wont leak or pop off.
Is the one on the car mounted to a plastic pipe?
You should be able to use an adaptor, sounds like thats what tsoob is talking about.
yees booy
Paulio
Postby tsoob » Wed Sep 09, 2009 4:17 pm
yep thats what i was on about, you could use a piece of alloy pipe thats the same size
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
