there is only about 5mm showing from the caliper, and its stuck tight.
I am thinking something like an easy out and then I'll need to redrill it and tap or helicoil a thread in it.
any suggestions for the easiest way to sort this?
evil_si wrote:if its protruding, or sticking out the best way imo is to weld a nut over top, the heat is usually enough to free it and it will unwind easily
