turbo extractors hitting oil filter
Postby tim_blair » Sun Sep 20, 2009 12:24 pm
i got myself some turbo extractors but when i tried to install it i found it was hitting my oil filter
my oil filter doesnt bolt directly onto the block
instead there is this alloy spacer (blacktop 4age)
its a standed item as i have seen it on many 4ages but i have also seen them without
i tried to remove it so i could put the filter directly onto the the block but it fits differntly
any susgestions as to how i can over come this problem
tim_blair
Postby groupagt4 » Sun Sep 20, 2009 12:44 pm
remote mount your filter. I had the same issue and thats what i ended up doing
groupagt4
Postby tim_blair » Sun Sep 20, 2009 1:53 pm
yea that what i thort but im unsure about the clearance ill get from doing it
im using one of those ssteel extractors from trademe
does yours have the alloy spacer that i mentioned?
would it be posible for you to take some pics of yours and email them to me?
tim_blair
Postby Crampy » Sun Sep 20, 2009 2:51 pm
Take that spacer off and bolt a filter relocation kit straight onto the block. You'll have all sorts of problems doing oil changes if it's going to be that close to the manifold.
Crampy
Postby TRD_ZERO » Sun Sep 20, 2009 3:40 pm
Or you can take that alloy thing off, take threaded tube off the center of alloy thing and screw it directly into the block and the oil filter should go straight into that.
Previous:
TRD_ZERO
Postby matt dunn » Sun Sep 20, 2009 7:29 pm
TRD_ZERO wrote:Or you can take that alloy thing off, take threaded tube off the center of alloy thing and screw it directly into the block and the oil filter should go straight into that.
yup, do that.
Postby tim_blair » Sun Sep 20, 2009 9:33 pm
Yea ill try do that and use an oil relocator kit but for memory its not taht easy coz the way the spacer is fitted to the block i dont think that i can just replace the thread thing but ill have a look when i do an oil filter change
tim_blair
Postby QikStarlie » Sun Sep 20, 2009 9:54 pm
yeh ya can, im using a 20v block with oil filter screwed straight to the block. think i stole the center threaded tube from a dead 16v.
QikStarlie
Postby themaleman » Sun Sep 20, 2009 10:55 pm
we made this for mine
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby CAMB01 » Sun Sep 20, 2009 11:11 pm
If you want to fit the filter onto the block, you will have to grab a threaded tube from a 16v block, as the 20v ones once you screw it into the block, doesnt leave enough thread to screw the filter onto. Been there tried that.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby TRD_ZERO » Mon Sep 21, 2009 7:23 pm
CAMB01 wrote:If you want to fit the filter onto the block, you will have to grab a threaded tube from a 16v block, as the 20v ones once you screw it into the block, doesnt leave enough thread to screw the filter onto. Been there tried that.
Is that just the case with filter and not a relocator kit? because im using the threaded tube from a 20v and my relocator kit screws onto it.
Previous:
TRD_ZERO
Postby Crampy » Mon Sep 21, 2009 7:29 pm
Crampy
Postby matt dunn » Mon Sep 21, 2009 8:27 pm
Crampy wrote:http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Core-engine/auction-243223452.htm
Do it.
still wont work as there will be nothiing in the block for it to screw too.
You will need the threaded tube.
Try genuine, i have bought one of two over the years from the dealerships, and if you get a deal they are not too bad.
Postby TRD_ZERO » Mon Sep 21, 2009 8:34 pm
My oil filter relocator kit screws onto the treaded thing off 20vs though. So whos to say this one wont?
Previous:
TRD_ZERO
Postby 0EBUNY » Mon Sep 21, 2009 9:55 pm
use a bluetop 16v or fe series threaded bolt to fit the oil filter......
new project
1998 toyota altezza :D where do i start plans go for miles
0EBUNY
Postby CAMB01 » Tue Sep 22, 2009 1:17 am
TRD_ZERO wrote:My oil filter relocator kit screws onto the treaded thing off 20vs though. So whos to say this one wont?
Only if you screw the filter onto the block.
The filter will go on, but with only a few threads till it becomes tight, as the tube is too short.
CAMB01
Postby Bazda » Wed Sep 23, 2009 1:54 am
I think I know what type of manifolds you bought.
As most people have said, remove the alloy spacer part, get the threaded tube bit out of a 16v block and screw that into the 20v block.
Use a oil filter that will fit with the manifold and turbo in place.
No need to waste you $ on an oil filter relocation kit, but ideally you should be running an oil cooler witha turbo setup!
Users browsing this forum: Google [Bot] and 20 guests
