Ignition Leads WTF!!!!
Postby loudstealthGT-Four » Sun Oct 11, 2009 7:37 pm
So last night a hose in my car split and spewed all the water/coolant out, the temp gauge started to go over half so i stopped and found some water and let it cool down, this didnt work so i towed it home. fixed the hose today filled it up with water and now it wont fire up, tried to take the leads out to see if they had any spark but they are stuck in there some how. managed to get 1 out and SUPRISE!!!!!!!!!!
Image Image
Image Image
Image Image
can any one tell me why the fcuk this has happened?????????
has any one else had this problem??????
Thanks Tyler
loudstealthGT-Four
Postby MR2BOY23 » Sun Oct 11, 2009 7:41 pm
That first picture is a bit blurry, has it melted? or has something else happend to it
MR2BOY23
meltdown
Postby fxgt race » Sun Oct 11, 2009 7:50 pm
Best you chip at what is left on the spark plug with a screw drive and hook a hose to a vacum cleaner that will fit down the spark plug hole to suck out the crap. A new leed and she be sweet.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby fivebob » Sun Oct 11, 2009 8:01 pm
It's melted because it overheated.
Are those genuine Toyota leads?
Postby loudstealthGT-Four » Sun Oct 11, 2009 8:07 pm
yea but i dont want to fork out another $180 because i only just got these in july. is it a fault of the leads or what?
yea there is a rubber bit at the end that in melted and Fcuked
loudstealthGT-Four
Postby loudstealthGT-Four » Sun Oct 11, 2009 8:09 pm
fivebob wrote:It's melted because it overheated.
No there Champion.........
It didnt overheat the temp gauge went just over half so i stopped???
loudstealthGT-Four
over heat
Postby fxgt race » Sun Oct 11, 2009 8:16 pm
If the temp gauge was only just over halve way when you stopped it should be ok , so hopefully the engine will be fine. check water in oil etc, put new leads on and give it ago
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Re: over heat
Postby loudstealthGT-Four » Sun Oct 11, 2009 8:19 pm
fxgt race wrote:If the temp gauge was only just over halve way when you stopped it should be ok , so hopefully the engine will be fine. check water in oil etc, put new leads on and give it ago
yea checked the oil its all good
cant afford some new leads though :(
loudstealthGT-Four
Postby fivebob » Sun Oct 11, 2009 8:22 pm
Thought so, genuine leads have rubber feet so they don't melt is situations like that. ;)
The condition of your plug leads says that it did.
Temperature sensors only really work properly when the're immersed in coolant, when it's just vapour they take a lot longer to react so the head would be a lot hotter than the gauge indicated.
Postby loudstealthGT-Four » Sun Oct 11, 2009 8:45 pm
oh ok thanks. (really hoping i havent $&#$% the motor)
loudstealthGT-Four
Postby DeeCee » Sun Oct 11, 2009 8:53 pm
i have some leads just floating around the place - pm me :)
GT Four Adovansu
DeeCee
Postby fivebob » Sun Oct 11, 2009 8:54 pm
loudstealthGT-Four wrote:oh ok thanks. (really hoping i havent $&#$% the motor)
Probably not, most of the melting would have occured after you shut the engine off as there was no coolant circulating to carry the heat away.
Worst that is likely to happen would be that the head has gone soft, but even that is unlikely.
Postby KwS » Sun Oct 11, 2009 9:16 pm
OH NOSE BHG!
:lol:
Man, i thought those leads would've been rated to like, hundreds of degrees....
KwS
Postby Akane » Sun Oct 11, 2009 9:19 pm
The million dollar question is, how is he gonna get the remaining bits out? :)
Postby jakesae101 » Sun Oct 11, 2009 9:21 pm
maybe its like that ad remove the sump then the crank, conrods and pistons to get to the spark plugs ???
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby KwS » Sun Oct 11, 2009 10:19 pm
tip engine upside down? Just get some mates together, get them to all grab the same side of the car, and lift. Problem solvered.
KwS
Re: meltdown
Postby frost » Sun Oct 11, 2009 10:39 pm
fxgt race wrote:Best you chip at what is left on the spark plug with a screw drive and hook a hose to a vacum cleaner that will fit down the spark plug hole to suck out the crap. A new leed and she be sweet.
Postby Lloyd » Sun Oct 11, 2009 10:40 pm
Mash the plastic bits with a screwdriver until its broken off and then blow compressed air down there
Postby sergei » Sun Oct 11, 2009 10:41 pm
superglue and a stick; smash the remaining bit to million of pieces and vacuum it; hook it with wire; etc
Postby loudstealthGT-Four » Sun Oct 11, 2009 10:58 pm
Will the spark plugs be $&#$%???
loudstealthGT-Four
