3S bellhousing question
Postby frost » Mon Jun 22, 2009 9:28 pm
yeah i noticed that too, but everything seems to mash together ok.
i've now gone gen4 3sgte and will get a proper ring gear for it.
Postby rxtoy » Sun Nov 01, 2009 8:28 pm
sooooooooooooo......................
trying to buy a Y bellhousing off a mate for this and i'm getting sick of the bellhousing collection i'm slowly amassing, he's got a 2Y with 4 speed, these the same as 4Y with 5 speed?????
its a convoluted story.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby frost » Sun Nov 01, 2009 9:10 pm
4 speed? steal case box? if so then no. wrong for you.
4 and 5 speed bell housing's don't swap over,
your after 2y 3y 4y 5speed w55 box only.
Postby KinLoud » Mon Nov 02, 2009 7:42 pm
4 speed might be a W45 or G45... alloy box.
Ken
Postby rxtoy » Mon Nov 02, 2009 10:30 pm
hmmm, i'll have to check it out.
are hilux box's w55????? i always thought the were something different. that would be handy though, leave me with a spare box for the stout in case of breakage.........................
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby evil_si » Tue Nov 03, 2009 7:14 am
hiluxs are generally a W series or a G series, and the input face is very similar they are interchangable,
on the 1uz adaptor plates that i do, they w series fits the hilux box they just have to be ground out a little to clear the g series input cover
evil_si
Postby AE25 » Wed Nov 04, 2009 2:07 am
yep w56, w59, g52, r151
do you also have to space the release bearing forward on the carrier to get a better clutch fork angle if you do not shave the 1s, 2s, 4s, 1c, 2c, 3c bellhousing with the 3s engine.
the gen5 beams altezza 3sge apparently has a different offset flywheel which fixes most of the usual issues converting 3s to rwd. and i read that the std dual-mass flywheel have issues and better to replace with aftermarket steel flywheel. you'd still need the double row spigot bearing with this i do assume?
also did you know there is a factory rwd 3s? comes in a sr40g and sr50g liteace as a 3sfe. unfortunately not a twincam. only the sr40g came with a manual with G52 according to toyodiy.com also distributorless!
looks like this
http://page18.auctions.yahoo.co.jp/jp/auction/w27996695
http://page2.auctions.yahoo.co.jp/jp/auction/b104932567
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
