ChaosAD wrote:Make sure you take it for a decent drive before buying it.
I picked up an auto bzg and it is completely guttless unless you have your foot to the floor or manually put it in 2nd gear.
Blacktops dont really make any torque until at least 3,000rpm yet the auto changes gear at about 2,000rpm![]()
The toyota boys must have been hitting the sake when they decided an auto blacktop was a good idea.
ebgamer wrote:crap... just went out and bought a 4L Magnatec 10w40 didn't see the post first.
My engine seems to be eating the current oil, Valvoline Engine Armour 15w40. but the oil is dirty as. I did an oil change 5-6 months ago but the old oil was in a terrible state as it had probably been a long time since it was last changed so im thinking there still might be a bit of gunk left over from that.
Another question... If i am using flush, do i have to replace the oil filter because i am using flush? The oil filter was changed 5-6 months ago.
And sorry regamaster for trolling your thread
- Cub3y
Dell'Orto wrote:Dont use an engine flushSlightly better way is to run diesel oil for a couple of thousand k's and dump it, it has far stronger detergents in it to deal with diesel blowby.
frost wrote:pics are better.
there is very little skirt under the pin, if i remember correct it was about 7mm under pin. silvertops have skirts like the 16valve engines and don't have this problem. i'll try and find a pic of the bore.
