Quirky wrote:Just a quick question, is a 4agze turbo fine to drive on the stock ecu with no tune (that's if you can tune it) 8psi of boost. Im getting my car back next week and it wont be getting an ecu for another 2 weeks after that.
Getting adaptronic put in. Heard good things, and at $1300 supplied and installed, its hard to pass up.
THA SHZ wrote:dont bother with the blue top cams they do nuthing of a noticeable difference
~SlideWays~ wrote:Quirky wrote:Just a quick question, is a 4agze turbo fine to drive on the stock ecu with no tune (that's if you can tune it) 8psi of boost. Im getting my car back next week and it wont be getting an ecu for another 2 weeks after that.
Should be perfectly fine at 8psi unless its an extremely efficient large turbo it will have enough fuel.
Don't push it until you get the new ecu AND tune then you will be fine.
d1 mule wrote:THA SHZ wrote:dont bother with the blue top cams they do nuthing of a noticeable difference
seeing as the cams have to come out anyway to get the head off, would it not be stupid no to put them in?? cant hurt can it....... im gonna be puttin mine in when the head goes back on
Quirky wrote:Somewhere on the Twincam site, someone did a dyno run comparing the 2 cams. He gained 2kw having swapped them over. But more importantly, i think the torque curve shifted earlier.
Crampy wrote:Quirky wrote:Somewhere on the Twincam site, someone did a dyno run comparing the 2 cams. He gained 2kw having swapped them over. But more importantly, i think the torque curve shifted earlier.
Doesn't sound like a waste of time then. My turbo Levin has Bluetop cams.
True-No-Turbo wrote:
but yeah that drop off they have at 5500 and boost cut at 15psi are the limiting factors.
try_hard wrote:thanks for the info. i think i will throw in the blue top cams as turboing is still on my mind. i'll have to wait untill the new year to decide what i want to do.
and for the turbo i currently have. is now on trade me.
have a mate in aus who can get a SC14 for $400AUS. now my mind is realy running in circles
