toyota piston part numbers??? 13101-16131-03
Postby d1 mule » Sat Nov 07, 2009 6:40 pm
hey all i have in my posession 6 X brand new 4agze pistons with pins and clips. The thing is i dont know if they are standard size or what C/R they are. can anyone tell by the pics and/or the part number, i have a feeling they are oversize 8:1 but dont want to guess as ill be selling 2 once i know
thanks
d1 mule
Postby Alex B » Sat Nov 07, 2009 6:43 pm
Did you try google the part number??
13101-16131-03 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGZE..AE101;STD,MARK 3
Looks like they are standard size to me.
http://www.wheelsjamaicahost.com/wheels ... 873.0;wap2
Postby d1 mule » Sat Nov 07, 2009 6:48 pm
lol didnt even think of that, cheers man. so they are 8.9:1 std sweet :D
d1 mule
Postby Mr Revhead » Sat Nov 07, 2009 7:30 pm
yeah the 03 is the grade ie where it fits in the tolerances on the production line
Postby KinLoud » Sun Nov 08, 2009 9:10 am
As Warwick says, 03 a code for production line clearances, you would put an 03 piston into an 03 size bore.
The 3 next to the arrow is the size marking.
When they bore and hone the cylinder in the factory you get slight variances in the actual diameter as the tools wear...
A similar thing happens with the machining of the pistons.
To keep the clearances very close to ideal they measure and mark the block with the size. The piston is also marked.
1 is smallest
2 is the most common
3 is biggest
So a 2 size bore gets a 2 size piston etc.
You can physically put a 3 piston into a 1 size bore but it might not have enough clearance.
Look here at pages 47 - 49 to get an idea
NOTE - they are talking about 4age clearances NOT 4agze (which need more clearance)
http://home.onthenet.com.au/~paulp/Blacktop/bt4-em.pdf
4agze clearance is 0.12-0.14mm!!!
Ken
Postby d1 mule » Sun Nov 08, 2009 11:00 am
thanks ken thats very helpful!! :D
d1 mule
