jakesae101 wrote:funny you say that sergei i used to use them quite a bit when i did lots of night driving in my escort handy on bits of motorway with no lighting i find it nice to see whats far ahead of me
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream wrote:BTW who changed my member status to The Devil![]()
Mr. Mainstream wrote:oh that looks choice jake, really good. i would have to mount mine externally due to them being slightly larger then those ones,
3.1 Application of headlamp requirements
3.1(1) A headlamp fitted to a motor vehicle must comply with 2.1 and 3.2.
3.1(2) A headlamp fitted to a vehicle must comply with an approved vehicle standard for headlamps if this is specified in Table
3.2 for that vehicle group or class.
3.1(3) A vehicle of Group A must comply with the relevant requirements in 3.3.
3.1(4) A motor vehicle of Group L, M or N, or an unclassified motor vehicle, that does not comply with an approved vehicle
standard for the installation of lighting equipment must comply with 3.3.
3.1(5) A vehicle retrofitted with a headlamp must comply with 3.3.
3.2 Safety requirements for headlamps
3.2(1) When operated, a headlamp must emit a beam of light that is substantially white or amber.
3.2(2) A main-beam headlamp must be able to be dipped or extinguished from the driver's seating position.
3.2(3) A warning device that is designed to indicate that the main-beam headlamp is in operation must, if fitted, be in good
working order.
3.2(4) The horizontal orientation of a headlamp on a vehicle must, when the vehicle's front wheels are pointing in the straightahead
position, ensure that the centre-line of the beam of light emitted from the lamp is projected either parallel to, or to
the left of, the longitudinal centre-line of the vehicle.
3.2(5) The vertical orientation of a main-beam headlamp on a vehicle must be such that, under all conditions of use, the centreline
of the beam of light emitted from the lamp does not rise above a plane that passes through the centre of the lamp and
is parallel to the surface on which the vehicle is standing.
3.2(6) A dipped-beam headlamp designed solely for a left-hand-drive motor vehicle, where the maximum intensity of the beam
is dispersed to the right, must not be fitted to a vehicle.
Angles of dip
3.2(7) A motor vehicle must comply with:
(a) the angle of dip specification in the approved vehicle standard that is applicable to that vehicle; or
(b) the requirements in 3.2(8), 3.2(9), 3.2(10) and 3.2(11).
3.2(8) The vertical inclination of the centre-line of the light beam of a symmetric dipped-beam headlamp on a motor vehicle of
Class LC, LD or LE, Group M or Group N, or an unclassified motor vehicle (other than one in Schedule 3), must be
between 3% and 3.5%.
3.2(9) The vertical inclination of the cut-off of the light beam of an asymmetric dipped-beam headlamp on a motor vehicle of
Class LC, LD or LE, Group M or Group N, or an unclassified motor vehicle (other than one in Schedule 3), must be within
the limits specified in Table 3.1.
Table 3.1 — Dipped-beam requirements according to height of headlamp
Height of headlamp lens Minimum dip Maximum dip
h1 ≤0.8m 1.0% 1.5%
0.8m≤h≤1.2m 1.0% 2.0%
h>1.2m 2.0% 2.5%
Note. “h” is the mounting height of the centre of the light source.
3.2(10) A motor vehicle equipped with dipped-beam headlamps that are able to be adjusted from the driver's seating position must
comply with the requirements in 3.2(8) or 3.2(9) with the adjustment in its highest position.
3.2(11) A motor vehicle that is equipped with self-levelling suspension must comply with the requirements in 3.2(8) or 3.2(9)
when the suspension is at its normal level.
3.3 Fitting and performance requirements for headlamps
3.3(1) A dipped-beam headlamp on a motor vehicle (other than an unclassified motor vehicle, or a vehicle having a gross vehicle
mass exceeding 12,000 kg) must be positioned at a height not exceeding 1.2 m from the ground.
3.3(2) A vehicle of Group A:
(a) may be fitted with one or two headlamps; and
(b) when operated during the hours of darkness, must be fitted with one or two headlamps that emit light that is visible
from a distance of 100 m.
3.3(3) If a vehicle of Group A is fitted with:
(a) one headlamp, that headlamp may be flashing;
(b) two headlamps, only one of the headlamps may be flashing.
Brookers Online http://www.brookersonline.co.nz 5
Section 3 Land Transport Rule: Vehicle Lighting 2004
3.3(4) A motor vehicle of Class LA or Class LB:
(a) must be fitted with one or two dipped-beam headlamps that, when operated, illuminate the road in front of the
vehicle for 30 m; and
(b) may be fitted with one or two main-beam headlamps.
3.3(5) A motor vehicle of Class LC, LD or LE:
vehicle for 50 m; and
3.3(6) A vehicle of Group M or Group N, or an unclassified motor vehicle (other than one in Schedule 3):
(a) must be fitted with one pair of dipped-beam headlamps that, when operated, illuminate the road in front of the
(b) may be fitted with one or two pairs of main-beam headlamps.
3.3(7) A motor vehicle in Schedule 3 (other than a trailer):
(a) may be fitted with one pair of dipped-beam headlamps; and
(b) may be fitted with one or two pairs of main-beam headlamps; and
(c) if operated during the hours of darkness, must be fitted with a pair of dipped-beam headlamps that emit light that
is visible from a distance of 100 m.
3.3(8) A motor vehicle of Group T must not be fitted with a headlamp.
10.1 Application of requirements for optional lamps
10.1(1) A motor vehicle fitted with an optional lamp must comply with 2.1 and with the requirements in Table 10.1, as applicable,
and either:
(a) the applicable fitting and performance requirements in this section; or
(b) an approved vehicle standard for the installation of that optional lamp.
10.1(2) A motor vehicle must not be retrofitted with a front fog lamp, a rear fog lamp, a daytime running lamp or a reversing lamp
on or after 1 January 2006 if that lamp does not comply with the applicable vehicle standards in Schedule 1.
10.1(3) A motor vehicle retrofitted with an optional lamp must comply with the applicable requirements in this section.
Table 10.1 — Safety requirements and approved vehicle standards for optional lamps
Component Vehicle Vehicle manufactured
before 1 January 1996
1996 and before 1
January 2006
2006
Front fog lamp Groups M, N Requirements in 2.1 and
10.2
Requirements in 2.1 and 10.2 approved and vehicle
standard for front fog lamps
Front fog lamp Group L Requirements in 2.1 and 10.2 Requirements in 2.1 and
10.2 and approved
vehicle standard for front
fog lamps
Rear fog lamp Groups M, N, L, T Requirements in 2.1 and 10.2 Requirements in 2.1 and
10.2 and approved
vehicle standard for rear
fog lamps
Daytime running
lamp
10.3
Requirements in 2.1 and 10.3 and approved vehicle
standard for daytime running lamps
Daytime running
lamp
Group L Requirements in 2.1 and 10.3 Requirements in 2.1 and
10.3 and approved
Reversing lamp Groups M, N Requirements in 2.1 and
10.5
Requirements in 2.1 and 10.5 and approved vehicle
standard for reversing lamps
Reversing lamp Group L Requirements in 2.1 and 10.5 Requirements in 2.1 and
10.5 and approved
reversing lamps
10.2 Fitting and performance requirements for fog lamps
10.2(1) The light emitted from a front fog lamp must be substantially white or amber.
Brookers Online http://www.brookersonline.co.nz 15
Section 10 Land Transport Rule: Vehicle Lighting 2004
10.2(2) The light emitted from a rear fog lamp must be diffuse and substantially red in colour.
10.2(3) A front fog lamp fitted to a motor vehicle must not be positioned higher than a dipped-beam headlamp fitted to the vehicle.
10.2(4) The horizontal orientation of a front fog lamp fitted to a motor vehicle must ensure that the centre-line of the beam of light
emitted from the lamp is projected either parallel to, or to the left of, the longitudinal centre-line of the vehicle.
10.2(5) When operated, a front fog lamp must emit a permanently dipped beam.
10.2(6) A front fog lamp fitted to a motor vehicle must be aligned so that the vertical inclination of the centre-line of the beam is
not less than 3%.
10.2(7) A fog lamp must be able to be extinguished from the driver's seating position, and a front or rear fog lamp warning device
that is fitted must be in good working order.
10.2(8) A motor vehicle of Group L may be fitted with one or two front fog lamps.
10.2(9) A motor vehicle of Group M or Group N, or an unclassified motor vehicle, may be fitted with one pair of front fog lamps.
10.2(10) A motor vehicle of Group L, M, N or T, or an unclassified motor vehicle, may be fitted with one or two rear fog lamps.
10.2(11) A vehicle of Group A or Group T must not be fitted with a front fog lamp.
10.2(12) A vehicle of Group A must not be fitted with a rear fog lamp.
10.3 Fitting and performance requirements for daytime running lamps
10.3(1) When operated, a daytime running lamp must emit light that is substantially white or amber.
10.3(2) A daytime running lamp must not operate when a front fog lamp or headlamp is in use.
10.3(3) A motor vehicle of Group L may be fitted with one or two daytime running lamps to the front of the vehicle.
10.3(4) A motor vehicle of Group M or Group N may be fitted with one pair of daytime running lamps to the front of the vehicle.
10.3(5) A vehicle of Group A or Group T, or an unclassified motor vehicle, must not be fitted with a daytime running lamp.
Users browsing this forum: No registered users and 32 guests
