flygt4 wrote:there also not much point doing a big burnout on most street tyres
pc wrote:keep lowing the pressure each run till the tyre turns on the rim then pump it up a little.
ch4ng wrote:pc wrote:keep lowing the pressure each run till the tyre turns on the rim then pump it up a little.
what do you mean by that?
i was launching at 3-3500, letting the clutch out quick but not dropping it, it would spin for one and a half seconds or so.
ch4ng wrote:i know for sure that ive got pretty low end tyres (sorry sam) but i do have an lsd so when i do do the usless burnout at the start i will at least be spinning up both wheels
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
