Quirky wrote:
I'm using one of those turbo smart boost tees
Car is running AE92 MAP ECU, which i think is the same as the ae101
Quirky wrote:If i remove the bleed tap it only runs on 4psi. Thats how they tuned it.
And I only get a crappy 82kw atw. They tried running 10psi but the ecu kept pulling the timing out and richening it. 4/5psi holds steady through the rev range. Any adjustments on that and the boost drops.
How do I increase boost without the bleed tap?
My car is getting an ECU next week, but im just impatient and want to see how the car runs on the standard ecu.
Quirky wrote:My car is getting an ECU next week, but im just impatient and want to see how the car runs on the standard ecu.
tsoob wrote:you really need to do a setup like mine, check out the project thread, ill put some more pics up
