kill switch
kill switch
Postby deaf_rattle » Tue Dec 08, 2009 9:27 pm
Looking at running a kill switch in the supra
was thinking of putting it inline with the 12v positive from boot to starter.
Is this the best place to run it? or better to do it inline with fuel pump or alternator line?
Postby jakesae101 » Tue Dec 08, 2009 9:28 pm
possibly better to kill the earth?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Lloyd » Tue Dec 08, 2009 9:32 pm
Kill switch as in "I'm leaving my car for 10 mins, I'll flick the switch" or as in "I'm leaving my car in the garage for a month, I'll flick the switch" ? If its the first one then don't both doing the starter or any high current stuff as its not worth it. And the alternator line? Thats just going to mean it drives until the battery runs out of go.
Tidiest way is to use a relay to cut ignition and/or fuel pump power. ECU power, starter solenoid etc
Postby themaleman » Tue Dec 08, 2009 9:39 pm
in both my cars i put the switch in the fuel pump positive wire. works great, car cant go anywhere unless its towed when the switch is off
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby xsspeed » Tue Dec 08, 2009 10:13 pm
iirc All that I or my mates have had, ground(?) the coil, so no ignition.
But these have been (all but one) carb'd cars so no use (I think anyway) putting it on the fuel pump (I presume cos the float would still have some fuel in it) - not applicable to you as you have efi though.
Postby matt dunn » Tue Dec 08, 2009 10:47 pm
Grounding the coil -ve is a good way to kill a car,
and to kill the coil.
Most electronic ignition coils will be stuffed if you leave the ign one for a while with the coil -ve grounded.
interupt Ign to the ECU,
Kill a dist signal wire
cut the ECU to Igniter signal,
etc etc
lots of better ways to do it.
Postby Bling » Tue Dec 08, 2009 10:59 pm
Last place i'd be posting where I was putting / thinking of putting my kill switch would be on the interwebs :lol:
Postby xsspeed » Tue Dec 08, 2009 11:41 pm
I understand your point, but its the how, not the where switch is...
Matt, these were all pretty old cars so perhaps no other option? Definately no ECU anyway.
Postby matt dunn » Tue Dec 08, 2009 11:59 pm
xsspeed wrote:I understand your point, but its the how, not the where switch is...
Anything with points and a mechanical fuel pump is almost impossible to immobilise electrically anyway, but yeah.
Postby deaf_rattle » Wed Dec 09, 2009 6:43 am
BZG|Bling wrote:Last place i'd be posting where I was putting / thinking of putting my kill switch would be on the interwebs :lol:
the car is alarmed, with dual immobiliser.
The kill switch is more for if something goes wrong i can pull the plug.
Postby D0DGEE » Wed Dec 09, 2009 7:42 am
get a main battery type switch with the red key and put it on the main battery cable inline the only thing u have to do is run a new alternator supply from the battery side of the switch to the alternator supply if u dont do this the car will still run when the switch is turned off.
D0DGEE
Postby KinLoud » Wed Dec 09, 2009 7:46 am
I'm guessing...
- your desire for a kill switch is not related to car security
- if you have a problem while driving you will turn the ignition key off
- you would like a kill switch somewhere in your car
Kill switch between battery and earth will make it safer easier to work on your car...
No big sparks when you accidently touch spanner to earth when undoing the positive battery connection first
No big sparks when you accidently touch spanner to block when undoing starter motor wiring
Note - a kill switch in your battery wiring won't stop the engine if it is running!
The alternator will still provide power to run computer and fuel pump!
Many a race car has failed scrutineering due to this! It has to interrupt power to the computer/pump
Ken
Postby 79rolla » Wed Dec 09, 2009 10:23 am
no there is an earth on the dizzy, if it is disconnected car will stop, trust me, it happened to me on the main street a while ago just as i was going past some people i didn't like :oops: hooked the wire back up and away i went!
past: AE82 FXGT
79rolla
Postby Bling » Wed Dec 09, 2009 4:28 pm
deaf_rattle wrote:The kill switch is more for if something goes wrong i can pull the plug.
Carry on then :lol: Could just copy a race car design they use with those big red keys you can remove? Not necessarily using the key switch, but cut power to the same parts etc.
Postby pc » Wed Dec 09, 2009 5:32 pm
You want something like this Image
It removes connection for ignition, fuel pump, and positive feed from battery. This will stop the engine, stop fuel from being pumped, and remove risk of electrical fire in engine bay when crashed. also the added bonus of being convenient to turn off when working on electrical stuff :D
Any race place should sell something to do the job.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
