thegreatestben wrote:If you are that concerned about that much stuff I would wait for the right aristo to come along.
thegreatestben wrote:Is the blue one you are talking about the TTE one?
You should have bought that
Dell'Orto wrote:http://www.landtransport.govt.nz/factsheets/44b.html
Could be tricky though, unless Aristos have had mention in the magazines mentioned
Crampy wrote:Dell'Orto wrote:http://www.landtransport.govt.nz/factsheets/44b.html
I see, cheers dude. Will look into it.
If I can find one I might just go for a JZX110.
FLAWLES wrote:the a341e trans are bullet proof, wont hurt to run a cooler on it, and i do recomend the oem toyota trans fulid,
alot of the jz pple i know seam to cry and whinge about about 100,000k service which is basicly cam belts to water pumps no biggy, really
plus the water pumps on both vvt-i 1jz and 2jz are the same, so tnz has them ex the shelf, alot of the parts are the same
turbos i wouldnt really worry about, whip the intale pipe of and have a check, i have found with ( the 1jzgte vvt-i ones anyway ) that the std by pass valve seams to be the cause of turbo issue's
again wouldnt worry to much
a twwwwoooo jaaaayyy zzzzz nut may want to clear some more issues up abit more than what i can
FLAWLES wrote:Crampy wrote:Dell'Orto wrote:http://www.landtransport.govt.nz/factsheets/44b.html
oh god yes ( should get your sh*t together and come drive my 100 )
you want me to post pic's for ideas and inspiration
cause i can
Crampy wrote:Nice, cheers J.
Howz your Chaser going?
Crampy wrote:Dell'Orto wrote:Apply for a Special Interest Vehicle ballot
Find sweet Aristo from Japan
Profit
How does that work?
I could be keen if it means getting getting a nice one from Japan.
Users browsing this forum: Bing [Bot] and 33 guests
