Anybody know if there is someone in NZ making polyurethane engine mounts.
Curren needs a new rear mount
Bazda wrote:Plus Plastics in east tamaki. $30-40 per mount to be refilled with Urethane witht he old mount burnt out.
Cheaper if you only want to leave the stock rubber in there and fill over it.
molex wrote:Bazda wrote:Plus Plastics in east tamaki. $30-40 per mount to be refilled with Urethane witht he old mount burnt out.
Hate to break it to you Bazda but their prices must have gone up.. last quote I had a month or two back was $60 each for small fwd mounts.
I ended up buying the urethane and doing it myself, $90 kit ended up doing 6 mounts with some to spare. Some I removed all of the rubber and poured it completely from urethane, some I left the stock rubber intact and filled in around it. Both worked very well. I used 80a shore rated stuff, if you leave the rubber intact they are very streetable.
molex wrote:I ended up buying the urethane and doing it myself, $90 kit ended up doing 6 mounts with some to spare. Some I removed all of the rubber and poured it completely from urethane, some I left the stock rubber intact and filled in around it. Both worked very well. I used 80a shore rated stuff, if you leave the rubber intact they are very streetable.
