4age smallport help?
Postby doin donuts » Tue Dec 15, 2009 11:01 pm
hey all, i have an ae85 levin, done a 4age smallport conversion. been along time in the build but finally road going. as of late it has a high pitch squeel when idling and driving in low revs, and seems to be clutch related ie when i use the clutch to get into gear. when i turn the car off and the engine has stopped for 1 or 2 after it does a higher pitched squeel. its not everytime i drive but when it does do it seems to be when been driving for 10+ minutes
now i know what most will say, check the belts but they have been checked and had 2 different mates that are damn good with cars and engines stand there and scratch their heads.
just wondering if anyone has had similar problems? any help will be greatly appreciated, i will try and video the sound so all can hear if it will help?
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby frost » Tue Dec 15, 2009 11:28 pm
might be clutch release bearing screaming from no grease when it heats up after 10minutes driving, this is last case scenario :)
they usually feel crunchy when spun buy hand when stuffed,
video wont help with E-nostic
best to try to isolate where the noise is coming from, long screw driver to ear and parts of engine/gearbox should help find something, (handle ends goes to ear :P )
Postby doin donuts » Tue Dec 15, 2009 11:33 pm
ok cheers frost will look into bearing, tried the screw dirver trick and cant figure it out.
doin donuts
Postby Flannelman » Wed Dec 16, 2009 12:09 am
check the spigot bering too
Flannelman
formerly known as Affroman
Re: 4age smallport help?
Postby ee904age » Wed Dec 16, 2009 6:59 pm
doin donuts wrote: when i turn the car off and the engine has stopped for 1 or 2 after it does a higher pitched squeel.
Release bearing would have been my first thought too except, release bearing wouldn't freewheel or have pressure on it after engine has stopped (with clutch disengaged)
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby doin donuts » Thu Dec 17, 2009 5:29 pm
well il have a look at bearings but either way holy hell its annoying!!
doin donuts
Postby 85AW20v » Thu Dec 17, 2009 7:55 pm
Could also be a vacuum or exhaust leak somewhere that only shows up when things have warmed up a bit. Use a piece of garden hose to get a more localised idea of where it's coming from.
See ya
Simon
85 MR2 20v
85AW20v
Postby doin donuts » Thu Dec 17, 2009 8:52 pm
leak? would that be be affected by the clutch?
doin donuts
Postby 85AW20v » Fri Dec 18, 2009 9:25 am
You don't know what moves when using the clutch. Things might just move enough to cause a leak. The hose will help you isolate where the nosise is coming from anyway.
See ya
Simon
85 MR2 20v
85AW20v
Postby allencr » Fri Dec 18, 2009 8:26 pm
Other then a fan clutch, there isn't much that will continue to move & possibly make a noise after the engine has stopped. Does it have a turbo?
A really loose, well broken in release/throwout bearing would have enough inertia to still spin a bit when the engine has stopped if it doesn't contact the clutch.
allencr
Postby doin donuts » Sat Dec 19, 2009 9:40 am
non turbo, well general idea is bearings. oh well guess im taking box off then
doin donuts
Postby rollaholic » Sat Dec 19, 2009 9:56 am
i actually think a recording of the sound could be useful in this instance
Postby doin donuts » Sat Dec 19, 2009 11:20 am
sweet i will try get one this weekend
doin donuts
Postby doin donuts » Sun Dec 20, 2009 1:06 pm
hey all, here they are, the first one is at idle, you can hear the sound, the second vid is of thee sound at idle then you can hear it get higher pitched car is turned off while im holding it in gear, doesnt do it when cars in neutral and turned off....
doin donuts
Postby rollaholic » Sun Dec 20, 2009 6:14 pm
man that is seriously high pitched, has it been doing it since you got it running? or recent addition
Postby 85AW20v » Sun Dec 20, 2009 9:20 pm
It could still be a vacuum leak, the way the noise drops off. Bit like squeezing the end of a ballon that you've blown up. Use the hose to isolate the area......
See ya
Simon
85 MR2 20v
85AW20v
Postby doin donuts » Sun Dec 20, 2009 9:59 pm
heya rollaholic, about a month or so after had it running it started, yeah will look at hoses mate, has all new aftermarket hoses so might be something like that, but weird how it makes that last high pitch squeel only when in gear
doin donuts
Postby 85AW20v » Mon Dec 21, 2009 12:57 am
When in gear there is less drag as the gearbox isn't turning as well so the engine will spin that little bit longer when you turn it off. You might find it does the same with only the clutch in and not in gear.
I think that maybe the pulsing in the noise is the increase in vacuum as the valves open in the area/runner that is leaking. It keeps going after switching off for a moment until there isn't any vacuum left.
And be careful with the hose in your ear - if you find the exact spot it'll just about deafen you!! If your mates thought it was the something to do with the clutch, start near the back of the intake.
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
