cedwards wrote:Try searching author "cat007" think he did it a while back. had some issues getting the driveshafts back in...
What clutch are you gonna use?
tsoob wrote:seems like the hard way to do it.
drain gearbox oil, drop the axels out of the hubs, remove from the box. remove box from engine change clutch. put it back in.
remove cam belt etc replace waterpump cam belt and tensioners etc. put it back in
engine never needs to come out for those jobs.
DeeCee wrote:BGB does explain how to remove the box with the engine in, but it is the long way around. As far as I know, dropping box + engine is easiest way to do it.
BTW, how do they do it on evos and other transverse mounted engine/4wd configurations if they don't drop it all out then? Go through removing the box with engine in car? eek..
Akane wrote: Pity fivebob is too poor to let things "get out of hand" and put some goodies in that engine.
Don't know about the gearbox but the cambelt can be done with the engine in the car, takes a good 4-6 hours on the SW20, it's the (lack of) gap between the engine and the strut tower that makes things difficult.
tsoob wrote:caldinas don't look that tough to me but ill have another closer look next one that comes in.
