20valve bogging down on hard throtle ....
Postby AceSniper » Tue Oct 13, 2009 7:31 pm
I would start with replacing the fuel filter if you don't know when it was last done.... quite common... enough fuel for slow but put your foot down and it bogs
AceSniper
Postby Crampy » Tue Oct 13, 2009 8:20 pm
96bzg wrote:what do you mean trouble codes how do you check them ?
Short out TE1 and E1 on the diagnostic plug in the engine bay. It'll flash the engine check light, and thus giving you any fault codes. All easily found on the interweb 8)
Crampy
Postby FLESHAXXE » Wed Oct 14, 2009 7:45 am
I have checked the fuel tank,and I mean taking it out and pouring the fuel out....and in doing so noted that the pump looks like new ...the inside of the tank is clean and the fuel that came out had a very small quantity of dust...and I mean you can hardly notice that there is dust in it...I have checked the rotor and distributor cap those are good...what I have done is check the code that I'm getting when I connect TE1 to E1 and it is code 21............
FLESHAXXE
Postby nmcgowan » Thu Oct 15, 2009 4:58 pm
21 is O2 sensor.
Behold the mighty SN1FTR.
nmcgowan
Postby Mr Revhead » Thu Oct 15, 2009 5:00 pm
you'd look pretty clean if you'd been soaked in petrol for 20 odd years too.
but you'd be f***ed....
Postby FLESHAXXE » Fri Oct 16, 2009 8:53 am
Changed O2 sensor but the same thing is happening.......this thing is driving me crazy....apart from that the dam car is idleing very high now...1300rpm.............
FLESHAXXE
Postby solidog » Sat Oct 17, 2009 12:39 am
nmcgowan wrote:Have a look through my posting. It has a number of different things you could look at, my problem ended up being a failing fuel pump that couldnt hold pressure reliably.
Low fuel pressure means low fuel flow, this means ya motor will idle OK, mabey rev out slowly and even drive. but under load the injectors open and drip if at all, misfiring, backfiring, it may seems like a timing or ignition fault but its a lack of timed/atomised fuel.
Its a thought, that would be a good reason for excessive rich running. although totally agree, you need to change the o2 sensor if its never been done, genuine retail & trade sucks ass, get a revised price if ya smart! 19 years old at the youngest aye
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
Postby solidog » Sat Oct 17, 2009 12:49 am
MAGN1T wrote:Your best bet would be to hook up a voltmeter to the oxy sensor and take a note of what readings you get Is the back of the car sooty looking?
Steve
DVOM faaaaaaaaaaaaaaaaaaaaar toooooooooooooooooooooooooooooooo slow to capture any kind of relevant or reliable reading! honest
solidog
Postby sergei » Sat Oct 17, 2009 9:10 am
Steve
Depending which one do you use. What you can do is hook up voltmeter to VF/E1 output, if it is 0 all the time, it means OX (Oxygen sensor) is most likely stuffed (as ECU is compensating what it sees as lean condition), if it 2.5V at idle @2000rpm then something else is faulty.
As for OX reading you need to see switch overs (going from near 0V to near 1V) and how fast it is switching, if it is jumping all over place, it is probably fine, if it is not outputting anything (stuck at 0V) it is most likely OX is clogged by sooth (at least, at most there is something else wrong and stuffed OX is a symptom). You can clean OX and check it at same time with butane torch, just hook up voltmeter and run the flame on the sensing end, if you start getting 1V steady out put, the OX is fine.
Postby FLESHAXXE » Wed Oct 21, 2009 4:37 am
changed the O2 sensor......still the same thing..........I have on an after market fuel pressure regulator....will put on the standard one and see how that goes...........
FLESHAXXE
Postby sergei » Wed Oct 21, 2009 8:07 am
FLESHAXXE wrote:changed the O2 sensor......still the same thing..........I have on an after market fuel pressure regulator....will put on the standard one and see how that goes...........
Is it one of those rising rates?
Those things are useless.
Postby FLESHAXXE » Wed Oct 28, 2009 7:42 am
I have replaced the aftermarket one with the standard one.....no change...Will be taking it to the mad scientist on thursday morning....will let you all know what is going on...thanks alot guys.....
FLESHAXXE
Postby FLESHAXXE » Sat Dec 19, 2009 6:44 am
Let me first say THANKS to everyone who gave me a bit of advise on what to do,however I found out that it was the fuel pump that was not delivering the correct volume of fuel when the engine was on load...THANKS again guys.......
FLESHAXXE
