Hi guys,
Im new to this forum and im hoping someone here can help me out with a couple of questions i have.
Ive just brought a caldina gtt and want to install a boost tap on it, when i was looking at the stock wastegate i see they run two pressure sources almost like an aftermarket one, which line do i run the tap on? the line that runs from the turbo to the side of the wastegate or the other that runs from the top to im guessing the intake?
Also whats the maximum boost the car can handle safely with only a 3" exhaust and pod filter? i was thinking 12psi?
any help would be much appreciated.
