ways to tell JZA70 and MA70 apart?
Postby MRDRFT » Sun Dec 20, 2009 8:53 pm
other than chassie number and motor!
any differance in brakes?
or wireing?
dash or anything?
thanks Brad
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby Py7h0n » Sun Dec 20, 2009 10:01 pm
Wiring looms are different - Both engine and dash
Gauges on dash are different
Diff is different
Steering Rack Ratio (JZA70R)
Shocks are different (JZA70R)
Interior is different (JZA70R)
Front Sway bar (bigger in JZ)
JZA70 shell has single skin at the rear gaurd, MA/GA70 has multiple skins (heavier)
Basically the JZA70 is a better car in almost every way.
Py7h0n
Postby MrOizo » Sun Dec 20, 2009 11:26 pm
Front lip on JZA70-R has 2 air ducts with ducting to the brakes.
MA70 has same lip wihout any holes or ducting.
MrOizo
Toyspeed Legend
Postby Py7h0n » Mon Dec 21, 2009 8:23 am
If you got the one with the lip :p
Py7h0n
Postby MrOizo » Mon Dec 21, 2009 9:44 am
Mine came with one - managed to get a TGP one a few months back ;)
MrOizo
Toyspeed Legend
Postby MRDRFT » Mon Dec 21, 2009 7:38 pm
ok so if i loook at my car what should i be looking at? haha it has adjusibul supention so that dosnt help it has 2 way diff so that dosnt help.
whats the differance in the looms?
mine has recaro interior.
how do you mean single skin?the guards are pritty thin if thats what you mean?
what gauges do the JZA70s have in the dash?
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby Py7h0n » Mon Dec 21, 2009 10:30 pm
looms are very different, plugs and all sorts.
yeah I mean the guards and if it is not a JZA70 it will have multiple skins and will be heavier. It's the one thing that can always tell a conversion apart from a factory car.
JZA70 has a battery gauge and a boost gauge and slightly different needles.
Py7h0n
Postby MRDRFT » Tue Dec 22, 2009 6:28 pm
yer well i have a boost and volt gauge...
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby Si » Sat Dec 26, 2009 11:26 pm
from memory the JZA70's had two layers of sound matting in the rear, MA70s and JZA70R's had a single layer
PS if you have a JZA70, dont ever $&#$% sell it. Mr Ozio will agree. Somedays I just want to slit my wrists.
Current: , '96 SubaruImpreza
Si
