deaf_rattle wrote:Is it possible to have a crank button with a stock ecu set up?
basically, it would be nice to have a crank only button to make sure i have oil pressure before engine start up.
Or is this too difficult?
Lloyd wrote:Just unplug coils, take plus out and wind it over on the key if its just initial start up. If you want it for every other time you start the car then there are other issues I think need addressed
pureadrenalin wrote:or get an acusump.
solves other problems too.
cat007 wrote:Get a Stinger ECU!
Put foot on gas above 90% to disable fuel and IG circuits.
Crank engine for however long you require
Release throttle
Engine starts
Done!
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
