My 1987 Hiace has a solid axel and something in the rear is getting louder and louder as time/km's go on (the van has done 350,000km's).
At about 40-60kmph there's a low pitched grinding that sounds like it's pulsing
Jacking up the back and spinning the drivers side wheel seems normal and quiet with minimal noise. Spinning the passenger side rear wheel how-ever is not so quiet.
I'm unsure how-ever, if it's the wheel bearing, or a diff bearing.
Also I've not worked on a solid axel vehicle since my school years when I had a 1980 XT Corona (3T with twin carb manifold off the 2T but with two larger 3T carbs on
Can anyone give me any pointers as to a) how to confirm if it's a wheel or diff bearing, and b) tips on how to fix either?
Cheers all
Hunt
