postfach wrote:something wrong with the booster perhaps?
fivebob wrote:postfach wrote:something wrong with the booster perhaps?
Not from the symptoms described, more likely a worn out master cylinder.
lucasthefallen wrote:pump it up with the motor off so it goes rock hard. hold the pedal down hard while starting the motor. if it slowly sinks to the floor thats normally a good sign that the booster is ok.
matt dunn wrote:postfach wrote:something wrong with the booster perhaps?
or perhaps there may be nothing wrong with it at all.
How spongy is spongy?
How does it compare to other toyota's for pedal feel?
iOnic wrote:How old is your brake fluid?
