4agte no spark
4agte no spark
Postby themaleman » Sun Jan 03, 2010 1:54 pm
ok got no spark :?
tried jumping it still no spark
all terminals ect are sweet
tried diagnostics and it gave me error 12,
12 RPM Signal
Diagnosis
* No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Trouble Area
* Distributor, or CPS, circuit
* Distributor or CPS
* Starter signal circuit
* ECU
the car is a map sensord ae92 gtz
can any1 tell me what i should do next, as in where do i check for the mentiond signals ect
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Sun Jan 03, 2010 3:31 pm
Try another CAS/Dist sensor.
Postby themaleman » Sun Jan 03, 2010 3:38 pm
is replacing the cas as simple as removing the old 1 and puting in the new 1? or is there a procedure i must folow to set it or something? thanks
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Rick » Sun Jan 03, 2010 3:47 pm
To rule out the wiring you can use a muiltimeter and check the continuity between the CAS and the ecu plug.
"G" is pin 16 on the "Z" plug of the ecu.
"NE" is pin 1 on the "a" plug of the ecu.
Postby Rick » Sun Jan 03, 2010 4:06 pm
Re: 4agte no spark
Postby 1hypo3 » Sun Jan 03, 2010 5:19 pm
themaleman wrote:ok got no spark :?
12 RPM Signal
Diagnosis
Trouble Area
* ECU
Can u get a hold of a scope?
ideally you need to scope ne and g signals for output
1hypo3
Postby themaleman » Sun Jan 03, 2010 5:21 pm
can u please explane, what dose a 'scope' look like?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Sun Jan 03, 2010 6:41 pm
Scope is like a high speed graphing multi-meter.
Has a screen like a heart rate monitor you see on TV.
And that diagram for replacing the CAS is for a dist'd one,
a CAS can be done by the same method but there is easier.
Take the top off it, ( 3 x 8mm bolts, IIRC)
turn the engine by hand until the single top tooth lines up with one of the sensors exactly,
remove it and fit the new one in so that the same part lines up with the same sensor in the same position.
You will need to get the teeth lined up and the dist twisted to the right place,
then do it up and put the lid back on.
You can check the CAS with a multi-meter if you know what you are doing, both resistance check and for AC voltage output,
but cant remember which wires are which from memory.
Postby KinLoud » Sun Jan 03, 2010 8:04 pm
was it running and now it doesn't go?
If it did go and now it doesn't what happened?
did you fiddle with anything?
Ken
Postby themaleman » Sun Jan 03, 2010 8:15 pm
well ive changed the engine and turbo, since then it hasnt started. about a month befor the old turbo blew i had been go-carting, and after the races as i left auckland raceway the car randomly died like 15 meters down the road, tried jumping it then and there with no joy, so had to tow it home. tried jumping it a day or 2 after that and it started sweet as as was running sweet since. we presumed it must have been flooded.
so im not sure weather its the same problem as when it died and woudnt start
i am certain everything is hooked up sweet. tho i need a knock sensor as the last 1 broke. hopfully get 1 from a wreckers on tuesday.
i have the cas from the previous engine so could change it. tho id like to be sure thats wat the problem is before i replace it
4agte ae92 Levin
a15 powered sj410
themaleman
Postby l1ttle_d3vil » Sun Jan 03, 2010 11:52 pm
have you got decent earths from engine to chassis? put another one on just incase, I had a dodgy one a while back so the engine sensors (inc dizzy) weren't earthed properly which meant no spark, no engine rpm etc.
Postby themaleman » Mon Jan 04, 2010 12:48 pm
yea baterys in boot, but weve run fat cable to the gearbox and to the chassis
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Mon Jan 04, 2010 6:14 pm
ok changed the cas, still no spark and still getting error 12
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Mon Jan 04, 2010 10:53 pm
error 12 RPM Signal
Diagnosis
* No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked*
would that stop the engine from firing?
i can get hold of a scope,
do i need to strip the loom by the ecu to check for signal on "NE" and "G"?
thanks for the input thus far
4agte ae92 Levin
a15 powered sj410
themaleman
Postby 1hypo3 » Tue Jan 05, 2010 7:22 am
themaleman wrote:error 12 RPM Signal
Diagnosis
Yes no Ne or G signals will stop engine from firing!
Use the scope and back probe Ne and G at computer if you have no signal check at CAS by back probe that way you check wiring as well at same time.
If you get a strong CLEAN signal at computer i would try another ecu.
I would start out by setting scope to around 1vdiv and 10ms for the trace and adjust if needed
1hypo3
Postby themaleman » Wed Jan 06, 2010 3:09 pm
changed ecu now shes sweet!! thanks people for the input!
4agte ae92 Levin
a15 powered sj410
themaleman
