Gizzmo MS-IBC any good?
Postby Crampy » Mon Jan 04, 2010 9:04 pm
I've heard bad thing about the original Gizzmo IBC, but this model seems to be good.
It has closed loop boost control, which in my eyes is a very good thing (a lot of EBCs dont have this function)
Plus it has the good ol scramble mode, so you can bump up the boost for a set amount of time.
And another big selling point for me is it doesn't stand out like dogs balls and I can also use it as a boost gauge.
Anyone using one of these? Are they all they're cracked up to be?
Crampy
Postby strx7 » Mon Jan 04, 2010 9:45 pm
I have one on my 5SGTE controlling a TIAL wastegate, very progressive for controlling the boost.
Postby matt dunn » Mon Jan 04, 2010 9:53 pm
strx7 wrote:I have one on my 5SGTE controlling a TIAL wastegate, very progressive for controlling the boost.
How hard and time consuming was the setup process?
I have one but have not used it as I was using an older HKS one,
but am really looking at runnning it if I cant get my other systems good enough.
Postby Crampy » Mon Jan 04, 2010 10:52 pm
So do they have a setting for actual boost level?
The old ones had gain and duty cycle (which set the boost.)
Seeing as this one has closed loop boost control, I'm assuming I can set a boost amount in psi without needing to drive the car. Is that a safe assumption?
EDIT:
Well, I've downloaded the instruction manual and no, it doesn't set boost level. It's still done with duty cycle, but once saved as a memory, it will give a read out of the boost pressure when each memory is selected.
Crampy
Postby strx7 » Tue Jan 05, 2010 6:38 am
its just a matter of going for a drive to set the various pressures you want.
