Mr.Phreak wrote:Most will have fusible links
matt dunn wrote:There should not be a fuse at all in the main starting current,
120A fuse for starting current,
MrOizo wrote:matt dunn wrote:There should not be a fuse at all in the main starting current,
I getting a little confused - I should or shouldn't?
I'll look at putting one of the ANL fuses in line from battery to the junction block at the front where the battery was.
Where can these be bought for 1-2GA cable DeeCee?
matt dunn wrote:A 150A fuse will pass more than 150A for a short time,
And the correct fuse rating should be 1.5 X the normal current.
