Anyone know what the standard diff ratio is on an AE86 from factory,
or diff code from a build plate and I can work it out.
matt
frost wrote:4.1 and 4.3 depending on the model, gtapex was the 4.1 and gtv was 4.3 i think, the three apex diffs ive had have been 4.1 and the one gtv was 4.3
all looked as if they have never been cracked open, if i can find my build plates i'll post them,
matt dunn wrote:Wonder what ratio's are out there for the AE85 S series diffs?
l1ttle_d3vil wrote:matt dunn wrote:Wonder what ratio's are out there for the AE85 S series diffs?
were there different series ae85 diffs?
I have two diff heads out of ae85s - no idea exactly what model/year, just know they're from an ae85.
pretty sure they're both different ratios, I can count the teeth on them if you want?
matt dunn wrote:l1ttle_d3vil wrote:matt dunn wrote:Wonder what ratio's are out there for the AE85 S series diffs?
Yeah if you could. may be keen to buy one if there's one somewhere near the AE86 ratio's.
mine is a 3.73 according to the build plate. S302 code.
matt dunn wrote:
So that would mean there are probably different speedo drive gears available?
matt dunn wrote:Yeah if you could. may be keen to buy one if there's one somewhere near the AE86 ratio's.
frost wrote:not sure on that but gtapex was a digital dash so maybe there is a correction factor in it,
