best place for intake temp sensor?
Postby themaleman » Wed Jan 06, 2010 8:08 pm
ok after changing my ecu the car runs now, no more error 12 :D
now getting error 24,
24 Intake air Temp Sensor Signal
Diagnosis
* Open or short circuit in intake air temp sensor signal (THA).
Trouble Area
* Intake air temp sensor circuit
* ECU
turns out there isnt one on my 4age intake manifold, now im wondering if the position of this sensor makes a difference? befor t/b or after?
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby deaf_rattle » Wed Jan 06, 2010 8:16 pm
is it afm? if so i thought most toyota intake temp sensors were in the afm housing.
Postby themaleman » Wed Jan 06, 2010 8:24 pm
nah its a late madel ae92, map sensored. i have the sensor off the old s/c intake, just needa know where bouts to put it
i would prefur to put it on the intercooler piping so i can take a section off and drill the whole and be able to vacume out the drilled metal
4agte ae92 Levin
a15 powered sj410
themaleman
Postby QikStarlie » Wed Jan 06, 2010 8:38 pm
in the intercooler pipe before throttle will work fine
QikStarlie
Postby themaleman » Wed Jan 06, 2010 8:45 pm
chur
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Stott69 » Thu Jan 07, 2010 12:32 pm
just a question....... wouldn't drilling a hole in the intake pipe after the turbo possibly cause a boost leak?
Image jzs147 Aristo money pit
Stott69
err
Postby ezy10s » Thu Jan 07, 2010 12:35 pm
only if you didnt fit the temp sensor and left the hole wide open it would....
Member #244
Gone fishing until further notice
ezy10s
Postby Akane » Thu Jan 07, 2010 8:01 pm
just after the throttle body in the intake manifold if you can.
I have it about 10cm before the TB, at idle all the air builds up in there, and gets crazy warm, while the engine's actually taking air from the cooler Idle bypass valve. Also air velocity is quite slow during very light throttle, although the airmass per volume will be greater...
but then my intake pipe is right above the engine....... but then I've put on Greddy reflective cloth over it.....
too much variables, Got pics of your setup? :D
pic of intake temp sensor
Yeah I know.. I can't find a pigtail for the sensor locally (yet).
Postby themaleman » Thu Jan 07, 2010 8:25 pm
got it on 2day, had 2 get a nut, m16x1.5 fine pitch i believe. $1 from the boltshop
[img][img]http://img85.imageshack.us/img85/3770/photo0027p.jpg[/img] Image[/img]
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Adoom » Thu Jan 07, 2010 9:06 pm
Akane wrote:
OMG!!! Your wire taping skills need serious work!!! :lol:
Adoom
