Has anyone on here ran an external igniter on their dizzy's
Postby crispy'86 » Fri Jan 08, 2010 8:55 am
Hey all, i'm running twin sidies on my 4age motor and have changed to an electronic distributor out of a 3a, it looks like these use the external igniter on coil setup . My question is has anyone done this arrangement as opposed to the internal igniter setup on theirs, and with powering up the distributor it has 2 wires 1 pink, 1 red, same with the igniter. So where do the wires connect on both the distributor and the igniter, does the dizzy use a wire off the negative to one wire but if so where does the other one go?
I haven't been able to find a 3au specific wiring diagram, just 4a corolla one which doesn't help me much due to 4a electronic setups all being internal igniter/coil
crispy'86
Postby matt dunn » Fri Jan 08, 2010 2:43 pm
all the 3A ones I have seen are all internal.
post up some pictures of the dist internals
and of the igniter,
and i'll be able to tell you how to wire it.
Postby crispy'86 » Fri Jan 08, 2010 10:14 pm
Image Those 2 igniters are of the suspected ecu trigered igniter
Image Distributor numbers
Image Inside distributor and wiring, pink and white coloured wires
Image These are of the module i think is the 3au module for the distributor, looks like maybe the white wire is the trigger wire
Image This is the 5 wire type which has 2 single wire plugs
crispy'86
Postby matt dunn » Fri Jan 08, 2010 10:53 pm
Hard to tell from those pics, but I have my suspicion none of them may be compatable.
the dist is just the normal 2 wire magnetic pickup,
but need a NON ECU controlled module to go with it.
Postby d1 mule » Sat Jan 09, 2010 4:44 am
there must be a reason why, people use modified 4K dizzys over the bolt in 3a option. Palmside auto in hoon hay do them for like 250
d1 mule
Postby crispy'86 » Sat Jan 09, 2010 10:13 am
I did get told early honda igniters can be used for this setup. With the 2 wire magnetic pickup does the pink one have power and white is the signal to the igniter?? I can maybe email you more pics if you want to Matt. Also there is the option of using the 4a electronic dizzy's off a 4af carb'd motor. Might look into that if i can't find the 4k-u dizzy internals. 2e corolla internals are they the same? The igniter with the ballast resistor is the one possibly that i need, but to keep cost down i'm trying to use the bits out of my parts range.
crispy'86
Postby matt dunn » Sat Jan 09, 2010 9:07 pm
crispy'86 wrote:I did get told early honda igniters can be used for this setup.
Yes they would work and are probabl quite available.
Small square ones about the size of a packet of matches.
crispy'86 wrote: With the 2 wire magnetic pickup does the pink one have power and white is the signal to the igniter??
No and no. Neither are power, neither are earth,
Simply reluctor + and - and no way to tell which one is which with a scope,
but it will run either way.
crispy'86 wrote: Also there is the option of using the 4a electronic dizzy's off a 4af carb'd motor.
Are they internal coil?
Postby crispy'86 » Sun Jan 10, 2010 11:12 am
matt dunn wrote:Simply reluctor + and - and no way to tell which one is which with a scope,
So they go into the igniter?? or to a coil as someone thought a coil with more than 3 ohms shouldn't be a problem.
matt dunn wrote:Are they internal coil?
Yes as far as i'm aware the ae9# 4af engines have internlal coil but will check that on our loan cars tomorrow when i'm back at work
crispy'86
Postby crispy'86 » Mon Jan 11, 2010 7:04 am
Actually looked at an ae9#, seems the drive is a bit different as they are driven off the end of the camshaft, not on the exhaust cam on the front with the gear
crispy'86
