Akane wrote:Wolfkatz has already done such a bracket to run big discs with willwood dynalites.
If you do such an adaptor, will this be for the 91 brakes or 93?
If you do upgrade the fronts, you need to adjust your proportion valve, or else you'll end up locking your fronts and have WORSE than before braking.
http://www.wolfkatz.com/products.php?cat=25
Needless to say, I have an interest in this. But I've always been fascinated by dual calipers as well, I think they're "teh sex"
pureadrenalin wrote:I may be interested as well, but need to research where I want to end up a little more before I commit to anything.
iOnic wrote:Yeah I know you're keen you were in my inbox sooner than I could post this up
2jayzgte: Any more details on the MR2's you saw with this sorta setup? PM if you'd like.
Bazda wrote:Good thing about wilwoods is that the pads are cheap and you have a whole heap of diff compounds.
Wilwood calipers are not actually that expensive.
2jayzgte wrote:I think you can get brand new Supra 4-pot callpers from Toyota for about $600.
2jayzgte wrote:One thing I will say about those Supra 4-pots is on the downside they weigh seriously 7 kgs for each caliper.
On the positive though they are designed to pull up a full weight 1700 plus kilo car the Supra and were responsible for stopping the Supra from 100 kph in about 32 metres which when they were designed back in the 90s was a record.It was only surpassed by the set-up on the GT2 Porsche turbo in 2003 so when this is taken into consideration I feel $600 is quite a cheap price for the calliper you will be getting which has heaps of stopping power.
I used these callipers for 5 years and in a 8 lap runs at Manfield I'd see 24 190 plus KPH stops with excellent stopping no rotor pad or calliper failiure bar 1 when I melted a set of Mintex 1166 pads in 30 odd laps.
