AE86 sway bars?
AE86 sway bars?
Postby matt dunn » Sat Jan 16, 2010 10:03 pm
The rear sway bar on my AE85 measures 14.0mm in dia
The rear sway bar on my DX race car measures 16.8mm in dia,
and looks to be the same shape and mounting etc.
Q. Is the standard AE86 rear sway bar 16.8mm?
If it is not then what is the standard AE86 dia?
If so, then what is there available that is bigger/stiffer for the rear?
Looks as though there is a Whiteline 18mm adjustable one?
Anyone tried these? or have one that I can try or buy?
Matt
Postby suberimakuri » Sun Jan 17, 2010 4:49 pm
86 one is thicker than 85.
cutting the ends and doubling up does work but naturally somewhat limited in adjustment.
suberimakuri
Postby matt dunn » Sun Jan 17, 2010 6:08 pm
suberimakuri wrote:86 one is thicker than 85.
I would have guessed that,
but is 16.8mm the standard AE86 one?
Postby suberimakuri » Sun Jan 17, 2010 10:45 pm
sorry pass.
suberimakuri
Postby matt dunn » Sun Jan 17, 2010 11:04 pm
suberimakuri wrote:sorry pass.
Yeah,
just need someone with an AE86 and a pair of calipers....................
Not to hard to measure,
I measued my AE85 one in place without jacking the car up.
Postby Rob_GTZ » Fri Jan 22, 2010 4:15 am
Standard AE86 is 16mm
Swaybar is the same on GT Apex models (Notch & Hatch) & Also on the GT Notch.
GTV Hatch is different, but I'm not sure what the diference is exactly
Also TRD Rear swaybay is 16mm, of solid construction, (not hollow) & is 70% stiffer than original item.
Cusco Rear Swaybar is 20mm diameter
Rob_GTZ
