Quirky wrote:Compresser surge takes forever to actually bust a turbo.
Your probably looking at 2-3 years before any damage is done, if that.
In Australia, its very common to run your turbo car with no blow off valve so you get the doseing. People run there cars for years...
matt dunn wrote:
And others it is quick.
We had a race car break a turbo within a few hours of running because the BOV was either jammed or not connected, cant remember which it was.
79rolla wrote:aftermarket bov? is the spring too hard causing compressor surge?? or maby your oil pressure is too high for the turbo and blowing the seails, or blocked drain pipe?? or not getting enough oil through and killing the berrings??
are you running turbo timer?
is it water cooled (overheating)
how is the turbo blowing?
just a few ideas off the top of my head..
iOnic wrote:mr2_8_u wrote:its botom feed oil side feed water.
Pic of this?
