Fitting boost gauge to 3sgte, need help
Postby dakine » Mon Jan 18, 2010 9:54 am
Can someone please post a picture of where they connected the feed from the boost gauge on a caldina gtt (3sgte)?? Or describe in great detail where it needs to go?
Thanks in advanced,
Mark
dakine
Postby MR2BOY23 » Mon Jan 18, 2010 10:12 am
Theres a line going from the bottom of the intake manifold to the factory denso pressure sensor I took it from there
MR2BOY23
Postby dakine » Mon Jan 18, 2010 10:13 am
cheers, il have a look when i get a break :)
dakine
Postby fivebob » Mon Jan 18, 2010 10:24 am
MR2BOY23 wrote:Theres a line going from the bottom of the intake manifold to the factory denso pressure sensor I took it from there
That might be ok on an AFM metered 3S-GTE but on a MAP based engine it's the wrong place to put it. It can affect the factory sensor reading, and worse still if the comes off under boost your engine will radically lean out and advance the ignition, which is not good for engine life expectancy.
Try putting it in the trigger line to the BOV if you want a safer place for it.
Postby dakine » Mon Jan 18, 2010 10:37 am
ok il try find that, it's got an aftermarket bov fitted so that should be a bit easier :) thanks heaps guys!!
dakine
Postby Boosted_162 » Mon Jan 18, 2010 4:29 pm
Thats nice to know! So glad now i didnt put mine on there...
Postby dakine » Mon Jan 18, 2010 8:06 pm
is there a sweetspot on the firewall for feeding the pressure line through? I'm having trouble finding something close enough to the drivers pillar
thanks,
mark
dakine
