ae111 c56 has a ceramic type coating on 2nd and 3rd syncros while c52 and ae101 c56 dont
Might be why shifting felt better? every box will be different depending on its life
If you end-up using C160, it is imperative you use synthetic GL4/5 Oil.
Stott69 wrote:If you end-up using C160, it is imperative you use synthetic GL4/5 Oil.
That may be why im crunching in R and 4th
On topic; the 6spd from super strut Bzrs are lsd, theres a thread in faq's on them I think. From what I've heared you would be better off with the 5spd and a lsd. The 6spds are the 5 speed box fined down to fit a extra gear in. Top gear is the same in both boxs but final drive depends on which diff you have.
But I could be wrong, correct me if I am
