Park lights staying on
Postby Emperor » Fri Jan 22, 2010 4:24 am
I know its not a Toyota, but just incase anyone has a fair idea, or has had the same problem..
I got home from town just before, jumped out of car, sweet as. Next thing park lights pop on... Went back in car made sure no switches were on, turned lights on and then off again, all was sweet for 5 seconds then they come back on..
Now I don't think there's a park light switch in the car, other than on the stalk.. So could it be a wiring issue? Ground etc? Ill give it a good check tomorrow, but thought i'd ask incase anyone on here has had this.
Emperor
Postby piw » Fri Jan 22, 2010 3:53 pm
kinda need to know what sort of car it is as different models have different features with lights.
piw
Postby Emperor » Fri Jan 22, 2010 4:06 pm
M35 Stagea sorry.
But I think its just another one of its problems. Now the gearbox is gone. Awesome :cry:
Emperor
Postby Alex B » Fri Jan 22, 2010 5:10 pm
Does it have an alarm? If so does it flash the park lights? Try and find the park light relay and give it a bash.
Postby Emperor » Fri Jan 22, 2010 5:49 pm
Nah, no alarm, and the central locking makes the indicators flash.
Its not doing it now. But my gearbox light is on, and it doesnt display with gear (P, R, N, D) on the dashboard, or make the reverse beep anymore. lol
Emperor
Postby Akane » Fri Jan 22, 2010 7:27 pm
Too much skids? lol
Postby strx7 » Fri Jan 22, 2010 9:56 pm
Emperor wrote:M35 Stagea sorry.
Sounds like the same headlight switch issue that the R32's had.......
Postby matt dunn » Fri Jan 22, 2010 11:09 pm
Is there an auto position on the headlight switch?
Cos some of the nissans that do have the relay pack by the radiator and they fill with water.
Postby Emperor » Sat Jan 23, 2010 3:28 am
Headlights are sweet, and gearbox is sweet now.. So over this car though!!
Emperor
Postby 3T-Rona » Sat Jan 23, 2010 9:27 am
sounds pretty typical nissan bud, the layers within the switch are really close together and eventually with heat etc the thin grease in the switch solidifies abit and power can track between the contacts,
if they stay on for a while you will be able to feel the heat from the bottom of the column, either remove it and clean it up or get a new switch ($150 odd)
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
