Crampy wrote:I must say I do like the idea of having twin mufflers. It would suit the look of the car better, as it comes stock with two.
I can't say I entirely agree that mufflers need to be straight through though. Properly designed turbo flow baffled/chambered mufflers still flow very well.
I do agree with needing big body mufflers. The fart cannon has no size to it, so will never soak up the sound as good as a big body oval muffler.
Crampy wrote:Also, out of interest, Does having the butterfly closed have any effect on fuel economy?
ChaosAD wrote:Obviously if you do anything to improve the breathing of the engine your going to use more fuel
Adamal wrote:ChaosAD wrote:Obviously if you do anything to improve the breathing of the engine your going to use more fuel
Hmm... Not necessarily. If you make it easier for your engine to breath, you're improving the efficiency.
If you remove a form of restriction, less force is required by the engine to push the exhaust out.
Its a very similar concept to rally cars using intake restrictors to restrict the HP.
Crampy wrote:Quint wrote:Will keep any eye on my economy now that i've freed up the exhaust. Should be better, by how much though.*shrug*
What's the car/engine and what exhaust have you got now? Just getting ideas going. Is it quiet, or loud but acceptable, or just down right rowdy?
mjrstar wrote:I have just de-fartcannoned my car. It had a fairly small silencer in it when i brought it, i have also gone from 2 1/2 inch to 3 inch.
The new exhaust is quieter although slightly deeper. It all comes down to ensuring you have a decent quality resinator and well made rear muffler to match. (and no 5 inch tips)
The car is slightly quieter than before and has gained a bit of low end boost response and like pulling passed 7000rpm now.
My old Mivec Diamante had the flapper by-pass in the exhaust, i guess it's of some use or they wouldn't bother doing it.
