Mr Revhead wrote:If you have a fault, fix it, but don't clear the codes then it can still run in limp mode.
fivebob wrote:Usually it will only check for a knock sensor failure after the engine is warmed up and exceeds 2000rpm while driving.
Mr Revhead wrote:fivebob wrote:Usually it will only check for a knock sensor failure after the engine is warmed up and exceeds 2000rpm while driving.
I have come across 4age's that will throw a code from dead cold once given a rev (prob exceeding 2k rpm) so maybe the warming up is not applicable to all? Having said that I think the specific one I am remembering had the sensor unplugged so maybe that was it.
