TRD_ZERO wrote:Im testing with the multimeter at the link plug end right?
Yes with everything plugged in except the ecu.
gasman wrote:what does the MAP say the pressure is when you have the link connected with out the engine cranking? should be about 101kPa
TRD_ZERO wrote:
Just tried it and im getting 253kpa with no vacume line.
TRD_ZERO wrote:I saw that option of turning it off but wasnt too sure if i should fiddle with that stuff as im no tuner. Will it be safe turning the map limit off. Im away for the weekend but ill try these things when i get back.
TRD_ZERO wrote:And what do you gather from the results i got from testing the triggers?
