ae82 front hubs Vs ae92 front hubs
Postby Bazda » Sun Jan 31, 2010 10:31 am
Just wanting to know if the ae82 front hubs are the same as ae92 front hubs?
Can the brakes off an ae92 be swapped to an ae82? Which means the mounting points of the calipers & offset of the drive flange on the ae82 are the same as ae92?
Postby jakesae101 » Sun Jan 31, 2010 10:44 am
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby CAMB01 » Sun Jan 31, 2010 11:25 am
Yes!
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Sun Jan 31, 2010 11:38 am
awesome guys. thanks.
Postby Paulio » Sun Jan 31, 2010 11:39 am
you working on an ae82 barry?
yees booy
Paulio
Postby Bazda » Sun Jan 31, 2010 11:45 am
Paulio wrote:you working on an ae82 barry?
Making a wilwood brake kit.
Postby pc » Sun Jan 31, 2010 6:59 pm
What size wheel will be required to go over the calipers?
I'm interested in looking at ways to get rid of sliders on the front brakes of my AE82.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Bazda » Sun Jan 31, 2010 7:33 pm
Currently making sets to fit all rims.
Quick list here.
14" Wheels - Dynalite Forged with 255mm x 25mm Disc
15" Wheels - Dynalite Forged with 280mm x 26mm Disc
15" Wheels - Dynalite Billet with 290mm x 32mm Disc (may not fit all 15" rims depending on rim style you have))
16" Wheels - Dynalite Billet with 300mm x 32mm Disc
16" Wheels - Superlite Forged with 300mm x 32mm Disc (may not fit all 16" rims depending on rim style you have)
17" Wheels - Superlite Forged with 315mm x 32mm Disc
PM me for more details.
Postby AE25 » Thu Feb 11, 2010 6:31 pm
ae82/ae92 have different bearing part number but not sure if size is actually different or not. ae92 by the looks of it has a shorter steering arm.
ive compared ae101 non superstrut to the ae82 and caliper interchange, disk offset listed as some on dba catalogue. locating hole different size 54 and 55mm. the axle flange is thicker on ae101 but is compensated in the shaft part where bearing fits on.
figured out an upgrade combo using ae82 hub/strut, aussie ae93 258x22 (54hole) and ae101 caliper. the ae93 disk matches jdm ae101 non superstrut disk in size but has the 54mm hole instead of 55mm.
bit off topic but might help in some way?
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
