g4 link
g4 link
Postby tsoob » Tue Feb 02, 2010 9:44 am
is anyone running one on a 4agte yet?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bazda » Tue Feb 02, 2010 10:10 am
Brendon runs the older one.
Bruce Cullimore runs the G4 on his integra 410kw atw. Said its a good ecu, not top of the line but def does all you need it to do.
Postby tsoob » Tue Feb 02, 2010 10:48 am
ok, according to link the base map may be ok for a startup but will need some configuration.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Tue Feb 02, 2010 11:52 am
tsoob wrote:ok, according to link the base map may be ok for a startup but will need some configuration.
Most base maps from reputable companies are like that. I dunno that I'd drive to the dyno on a generic base map though. If the timings out it could overheat and stress the engine - or too rich and you'll bore wash etc etc.
I think they're really just designed just to get the engine running ready for the dyno - rather than driven there....??
Hey bro, off topic - but any luck with that video of hampton downs?
Postby matt dunn » Tue Feb 02, 2010 1:07 pm
If you buy a brand new Link there is no base map.
they all come with some numbers programmed in them,
but I would not call it a base map,
and they are all shipped the same so the one you get for a 20V has the same numbers as the one you get for a 7L supercharged V8.
It will also need configuring as you have to program each pin as to what you have connected to it, Injectors, number of coils, which one is FP drive etc etc.
Postby tsoob » Tue Feb 02, 2010 1:51 pm
matt dunn wrote:If you buy a brand new Link there is no base map.
yeah i have been talking to them today. I have someone who can wire and configure it, but i would really like to have some sort of tune in it to save $$ on the dyno, the car already has had around 2ks worth of dyno time
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby QikStarlie » Tue Feb 02, 2010 5:14 pm
it is possible to copy an paste the numbers from g3 fuel and ignition maps onto the g4. long as all the load points and rpm points are set the same. i have a couple of 16v 4agte g3 tunes you could do this with. or i can copy the g3 maps into into a g4 file if your unsure. you'd still need to configure the rest , plus play with the master fuel to suit your injector size. but it should save you a bit of dyno time. as at least the cruise part of the map will be fairly close once master is set right
QikStarlie
Postby thegreatestben » Tue Feb 02, 2010 7:59 pm
Also have a very swish g3 4agte tune on file here.
thegreatestben
Postby XSVWGN » Tue Feb 02, 2010 10:34 pm
I will be getting the G4 storm for my wagon (20v 4agte). The advantage i have here with speedtech is that justins (gasman) tune is on file and apart from the turbo we are running the same engine etc ;)
Matt
2008 Kia rio - work car
XSVWGN
Postby tsoob » Tue Feb 02, 2010 10:48 pm
XSVWGN wrote:I will be getting the G4 storm for my wagon (20v 4agte). The advantage i have here with speedtech is that justins (gasman) tune is on file and apart from the turbo we are running the same engine etc ;)
Matt
is he running a storm?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby XSVWGN » Tue Feb 02, 2010 10:51 pm
nah he has a lem v3 i think
XSVWGN
Postby matt dunn » Tue Feb 02, 2010 11:12 pm
XSVWGN wrote:nah he has a lem v3 i think
LEM V3 and LEM G3
are about as similar as a Chev(rolet) and a Chev(ette)
no similarity at all,
no compatable programs and dont run the same version of PC link,
And LEM V3 is about 10+ years old,
Postby XSVWGN » Tue Feb 02, 2010 11:43 pm
lem G3 then ;)
XSVWGN
Postby TRD_ZERO » Wed Feb 03, 2010 9:31 am
Yes he is running a g3 i got the tune off him too to run my engine. The thing is will a G3 map work on a g4?
Previous:
TRD_ZERO
Postby tsoob » Wed Feb 03, 2010 10:38 am
ok. they arent the same but they are.
if you had the map from the g3 open on one window and entered it manually to the g4 window on pc link you could create a map as such.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby IH8TEC » Wed Feb 03, 2010 11:10 am
can borrow mine if ya like nick, for 9.1:1 compression. but apart from that i think your running similar to what i am, justmight need to adjust the master fuel like kris mentioned.
PM me if you want.
Postby tsoob » Wed Feb 03, 2010 4:13 pm
thanks guys, my cousin has a map from a 4agte with 220kw we are gonna use, should work pretty well.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
