tsoob wrote:ok, according to link the base map may be ok for a startup but will need some configuration.
matt dunn wrote:If you buy a brand new Link there is no base map.
they all come with some numbers programmed in them,
but I would not call it a base map,
and they are all shipped the same so the one you get for a 20V has the same numbers as the one you get for a 7L supercharged V8.
It will also need configuring as you have to program each pin as to what you have connected to it, Injectors, number of coils, which one is FP drive etc etc.
XSVWGN wrote:I will be getting the G4 storm for my wagon (20v 4agte). The advantage i have here with speedtech is that justins (gasman) tune is on file and apart from the turbo we are running the same engine etc
Matt
XSVWGN wrote:nah he has a lem v3 i think
